Hama Tilt TV Wall Bracket26" Black
Quicklinx: D1S9WS00 Mfr#: 00108752
Hama Tilt TV Wall Bracket is for the installation of screen sizes 10" to 26". The easy to use syatem allows for optimal positioning of you flat screen TV.
Hama MOTION TV Wall Bracket, 1 star, XS mounting kit - for flat panel - black
Mounting kit
Mounting Components
Wall bracket
11.5 cm x 8.55 cm x 11.5 cm
Recommended Use
Flat panel
Recommended Display Size
10"-26"
VESA Mounting Interface
100 x 100 mm, 75 x 75 mm, 50 x 50 mm
Max Load Weight
10 kg
Material
Steel
11.5 cm
8.55 cm
11.5 cm
Material
Steel
AV Furniture
Mounting kit
Mounting Components
Wall bracket
Recommended Use
Flat panel
10"-26"
Max Load Weight
10 kg
Adjustable angle
