The Hama Tilt TV Wall Backet has an Easy-Fix system for simple installation and offers fully adjustable orientation of your TV. It also has an integrated spirit level for fast and easy mounting.
- Hama TILT TV Wall Bracket, 1 star mounting kit - Easy-Fix - for TV - black
- Product Type
- Mounting kit (Easy-Fix) - wall-mountable
- Mounting Components
- Wall bracket, mounting hardware
- Integrated Devices
- Spirit level
- 42 cm x 2.8 cm x 42 cm
- Tilt
- -12°
- Recommended Use
- TV
- Recommended Display Size
- 32"-65"
- VESA Mounting Interface
- 100 x 100 mm, 200 x 200 mm, 400 x 400 mm, 300 x 300 mm
- Max Load Weight
- 35 kg
- Material
- Steel
- Black
- 2-year warranty
- 42 cm
- 2.8 cm
- 42 cm
- Material
- Steel
- Black
AV Furniture
- Mounting kit
- Design
- Easy-Fix
- Recommended Use
- TV
- Placing / Mounting
- Wall-mountable
- Spirit level
- 32"-65"
- Tilt
- -12°
- Max Load Weight
- 35 kg
- Limited warranty - 2 years
