Hama Ultraslim Fullmotion TV Wall Bracket 65"
Quicklinx: D1S4WS00 Mfr#: 00108751
The Ultraslim Fullmotion TV bracket from Hama offers a fantastic range of orientation allowing your TV to be tilted and swivelled to suit your needs. The extremely flat profile means that it is easily hidden behind the screen.
Hama "Ultraslim" FULLMOTION TV Wall Bracket, 3 stars, XL, 2 arms - mounting kit - for flat panel - black
Mounting kit - wall-mountable
Mounting Components
2 articulating arms, 3 joints, wall mount bracket
Recommended Use
Flat panel
Recommended Display Size
37"-65"
VESA Mounting Interface
100 x 100 mm, 200 x 200 mm, 400 x 300 mm, 400 x 200 mm, 400 x 400 mm, 600 x 400 mm, 600 x 200 mm, 300 x 200 mm, 300 x 100 mm, 200 x 100 mm, 300 x 300 mm, 600 x 300 mm, 500 x 400 mm, 600 x 500 mm, 200 x 300 mm, 300 x 400 mm
Max Load Weight
35 kg
Material
Steel
Material
Steel
AV Furniture
Mounting kit
Mounting Components
Recommended Use
Flat panel
Placing / Mounting
Wall-mountable
37"-65"
Max Load Weight
35 kg
Rotating, swivel adjustment
