Own what professionals use to take control of the room and a laptops cursor with the Expert Wireless Presenter with Red Laser Pointer & Cursor Control. Sometimes pointing just isnt enough. With a simple flick of a switch, you toggle between presentation and cursor control modes. The wireless 2.4GHz receiver stores conveniently inside the remote, and since its uniquely paired, you dont have to worry about device interference.
Effortless control
The Kensington Presenter Expert is designed with backlit buttons and a built-in laser pointer, ensuring seamless presentations even in fully lit or dark environments. -
Extended reach
With a maximum operating distance of 50 m, this presentation remote control offers the freedom to move around large rooms or auditoriums, engaging with the audience without being tethered to a device. -
Reliable performance
Equipped with a low battery alert and an easy power on/off feature, the Kensington Presenter Expert ensures your presentations go smoothly without interruptions for battery changes.
- Kensington Presenter Expert Red Laser with Cursor Control presentation remote control - black
- Presentation remote control
- Enclosure Colour
- Black
- Localisation
- Europe
- Connectivity Technology
- Radio
- Max Operating Distance
- 50 m
- Battery
- Pointing device battery
- Enclosure Colour
- Black
- Localisation
- Europe
- Radio
- 50 m
- Low battery alert, built-in laser pointer, back-lit buttons, power on/off
- Operating System
- Apple Mac OS, MS Windows 7, Windows 8
- Included Accessories
- Carrying pouch
- Battery
