An easy-fix system for the installation of flat screen TV's from 19" to 46". The tilt aspect allows for optimal positioning in every room.
- Hama MOTION TV Wall Bracket, 1 star, L mounting kit - for TV - black
- Product Type
- Mounting kit - wall-mountable
- Mounting Components
- Wall mount
- 24.5 cm x 5.2 cm x 23 cm
- Adjustments
- Tilt
- Recommended Use
- TV
- Recommended Display Size
- 10"-46"
- VESA Mounting Interface
- 100 x 100 mm, 75 x 75 mm, 200 x 200 mm, 50 x 50 mm, 200 x 100 mm
- Max Load Weight
- 25 kg
- Material
- Metal
- Black
- 2-year warranty
- 24.5 cm
- 5.2 cm
- 23 cm
- Material
- Metal
- Black
AV Furniture
- Mounting kit
- Wall mount
- Recommended Use
- TV
- Placing / Mounting
- Wall-mountable
- 10"-46"
- Adjustments
- Tilt
- Max Load Weight
- 25 kg
- Easy-Fix system
- Limited warranty - 2 years
