Easy flat screen installation with Hama's Tilt Wall Bracket. The flat profile means that it is well hidden behind the TV and saves space in your room.
- Hama "Next Light" mounting kit - for flat panel - black
- Product Type
- Mounting kit - wall-mountable
- 28 cm x 4.2 cm x 14 cm
- Adjustments
- Tilt
- Recommended Use
- Flat panel
- Recommended Display Size
- 10"-37"
- VESA Mounting Interface
- 100 x 100 mm, 200 x 200 mm, 200 x 100 mm
- Max Load Weight
- 25 kg
- Material
- Steel
- Black
- 28 cm
- 4.2 cm
- 14 cm
- Material
- Steel
- Black
AV Furniture
- Mounting kit
- Recommended Use
- Flat panel
- Placing / Mounting
- Wall-mountable
- 10"-37"
- Adjustments
- Tilt
- Max Load Weight
- 25 kg
