The extremely flat profile of Hama's Ultraslim Fullmotion Wall Backet allows for modern and space-saving interior design. The Easy-Fix system means simple installation and fully adjustable orientation of your TV.An intergrated cable manager provides organisation and necessary strain relief.
- Hama "Ultraslim" FULLMOTION TV Wall Bracket, 3 stars, L - mounting kit - for flat panel - black
- Product Type
- Mounting kit - wall-mountable
- Adjustments
- Tilt
- Recommended Use
- Flat panel
- Recommended Display Size
- 32"-56"
- VESA Mounting Interface
- 100 x 100 mm, 75 x 75 mm, 200 x 200 mm, 800 x 500 mm, 800 x 800 mm, 400 x 300 mm, 50 x 50 mm, 400 x 200 mm, 400 x 400 mm, 800 x 400 mm, 600 x 400 mm, 600 x 200 mm, 300 x 200 mm, 300 x 100 mm, 600 x 600 mm, 200 x 100 mm, 800 x 600 mm, 800 x 200 mm, 300 x 300 mm, 600 x 300 mm, 600 x 500 mm, 200 x 300 mm, 300 x 400 mm, 600 x 800 mm
- Max Load Weight
- 25 kg
- Material
- Steel
- Black
- Material
- Steel
- Black
AV Furniture
- Mounting kit
- Recommended Use
- Flat panel
- Placing / Mounting
- Wall-mountable
- 32"-56"
- Adjustments
- Tilt
- Max Load Weight
- 25 kg
- Swivel adjustment
