Hama Fullmotion TV Wall mount has a cable manager for fantastic organisation of all those cables. The easy-fit system makes it simple to install and gives a fully adjustable oritentation for you TV.
- Hama FULLMOTION TV Wall Bracket, 1 star - mounting kit
- Product Type
- Mounting kit
- Mounting Components
- Swing arm wall mount
- Adjustable Depth
- 5.6-22.2 cm
- Tilt
- -12° to 5°
- Adjustments
- Tilt, swivel
- Recommended Use
- LCD display
- Recommended Display Size
- 19"-48"
- VESA Mounting Interface
- 100 x 100 mm, 75 x 75 mm, 200 x 200 mm, 200 x 100 mm
- Max Load Weight
- 20 kg
- Material
- Steel
- Black
- 2-year warranty
- Adjustable Depth
- 5.6-22.2 cm
- Material
- Steel
- Black
AV Furniture
- Mounting kit
- Recommended Use
- LCD display
- Cable Management
- Integrated cable management
- 19"-48"
- Tilt
- -12° to 5°
- Adjustments
- Tilt, swivel
- Max Load Weight
- 20 kg
- Limited warranty - 2 years
