Hama Fix TV Wall Bracket 48" Black
Quicklinx: D1SBWS00 Mfr#: 00118106
The extremely flat profile of Hama's Ultraslim Fullmotion Wall Backet allows for modern and space-saving interior design. The Easy-Fix system means simple installation and fully adjustable orientation of your TV.An intergrated cable manager provides organisation and necessary strain relief.
Hama FIX TV Wall Bracket bracket - for LCD TV - black
Bracket - wall-mountable
22 cm x 2.3 cm x 22 cm
Recommended Use
LCD TV
Recommended Display Size
19"-48"
VESA Mounting Interface
Up to 200 x 200 mm, from 50 x 50 mm
Max Load Weight
25 kg
Material
Steel
22 cm
2.3 cm
22 cm
Material
Steel
AV Furniture
Bracket
Recommended Use
LCD TV
Placing / Mounting
Wall-mountable
19"-48"
Max Load Weight
25 kg
Dimensions & Weight Details
Dimensions
Plate - width: 22.9 cm height: 9.6 cm
