Transform your paper documents into useful electronic data in a flash with the intelligent scanning features of the Fujitsu fi-6770 production scanner. Designed with outstanding paper handling, high scan speeds of up to 90ppm / 180ipm and intelligent productivity enhancement features, the Fujitsu fi-6770 scanner delivers the automation and dependability needed for production scanning applications. The Fujitsu fi-6770's innovative intelligent multi-feed function drastically improves the batch scanning process by allowing the ultrasonic double-feed detection sensor to be trained to ignore intentional overlapping documents such as photos, label stickers, or taped-on receipts. The Fujitsu fi-6770 color scanner comes additionally bundled with PaperStream IP and PaperStream Capture for enhanced batch processing and image enhancement.
In keeping with Fujitsu's long-standing commitment to safeguarding the environment, the fi-6770 is the business scanner to adhere to strictest ecological regulations throughout the entire manufacturing process. The design and manufacture of the fi-6770 meet Energy Star's energy consumption requirements and the European Union's Reduction of Hazardous Substances and Volatile Organic Compounds regulations.
Advanced scanning intelligence, high reliability, increased productivity
Transform your paper documents into useful electronic data in a flash with the intelligent scanning features of the Fujitsu fi-6770 production scanner. Designed with outstanding paper handling, high scan speeds of up to 90ppm / 180ipm and intelligent productivity enhancement features, the Fujitsu fi-6770 scanner delivers the automation and dependability needed for production scanning applications. The Fujitsu fi-6770's innovative intelligent multi-feed function drastically improves the batch scanning process by allowing the ultrasonic double-feed detection sensor to be trained to ignore intentional overlapping documents such as photos, label stickers, or taped-on receipts. -
High-impact scanning, low environmental impact
- Fujitsu fi-6770 - document scanner - desktop - USB 2.0, SCSI
- Document scanner - desktop
- Interface Type
- USB 2.0, SCSI
- Scanning Sensor Type
- CCD
- Max Supported Document Size
- ANSI B (Ledger) (279 x 432 mm)
- Input Type
- Grayscale / Color Depth
- 10-bit grey
- Grayscale / Color Depth (External)
- 8-bit (256 grey levels) / 24-bit (16.7 million colours)
- Optical Resolution
- 600 dpi x 600 dpi
- Max Document Scan Speed
- 90 ppm (mono) / 90 ppm (colour)
- Max Document Size
- 279 mm x 432 mm
- Automatic Duplexing
- Supported Document Type
- Plain paper
- Document Feeder Type
- Automatic
- Document Storage Capacity
- 200 sheets
- Duty Cycle
- 15000 scans per day
- Power
- AC 120/230 V (50/60 Hz)
- System Requirements
- Microsoft Windows Vista (32/64 bits), Microsoft Windows Server 2008 R2 x64 Edition, Microsoft Windows 7 (32/64 bits), Microsoft Windows XP (32/64 bits), Microsoft Windows Server 2008 (32/64-bits), Windows 8 (32/64 bits), Microsoft Windows Server 2012 x64 Edition, Windows 8.1 (32/64 bits), Microsoft Windows Server 2012 R2 x64 Edition, Windows 10 (32/64 bits)
- 50 cm x 69 cm x 34.3 cm
- 35 kg
- Environmental Standards
- ENERGY STAR Qualified
- Interface Type
- USB 2.0, SCSI
Scanner
- Input Type
- Grayscale Depth
- 10-bit grey
- Grayscale Depth (External)
- Colour Depth (External)
- 24-bit (16.7 million colours)
- 600 dpi x 600 dpi
- CCD
- Max Document Scan Speed B/W
- 90 ppm
- Max Document Scan Speed Colour
- 90 ppm
- Duty Cycle
- Scanner Speed Details
- 90 ppm - black & white , 90 ppm - colour , 180 ipm - duplex - black & white , 180 ipm - duplex - colour
- Scanner Features
- Ultrasonic Double Feed Detection
- TWAIN, ISIS
Media Handling
- Max Document Size
- 279 mm x 432 mm
- Plain paper
- Automatic
- 200 sheets
- Interfaces Details
- Ultra SCSI - HD-68 , USB 2.0 - Type B
- EPEAT Compliant
- EPEAT Silver
- ENERGY STAR Certified
- Power Device
- Internal power supply
- Voltage Required
- Power Consumption Operational (Standby)
- 216 Watt (6 Watt)
- Software Included
- ScanSnap Manager, Scanner Central Admin, Software Operation Panel, PaperStream IP, PaperStream Capture
- OS Required
- 50 cm
- 69 cm
- 34.3 cm
- 35 kg
- 5 °C
- 35 °C
- 20 - 80%
- Sound Emission
- 53 dB
