Fujitsu fi-65F A6 Small Format Flatbed Scanner
Quicklinx: C38VWS00 Mfr#: PA03595-B001
  • Windows 8 (32/64 bits)
  • Windows 8.1 (32/64 bits)
The compact, lightweight fi-65F scanner is ideal for busy office and retail environments. It quickly scans important, small documents like passports, IDs, prescriptions, driving licences, customer and medical cards and photographs, and seamlessly integrates with virtually any line of business application (LoB).
  • Energy efficient
    With its ENERGY STAR certification, this flatbed scanner meets strict energy efficiency guidelines, ensuring lower energy costs and a reduced environmental footprint.
  • Versatile scanning
    Equipped with a manual document feeder and the ability to scan a wide range of document sizes up to A6, this scanner is designed for flexibility in handling various document types and sizes.
  • High-quality imaging
    Featuring a color depth of 24-bit and grayscale depth of 8-bit, the scanner produces high-quality images with up to 600 DPI resolution, capturing every detail with precision.
  • Fast and efficient
    Achieve rapid scanning speeds with the device's ability to scan A6 documents in as little as 1 second in grayscale and B&W modes, and 1.7 seconds in color mode when AC powered.
  • Compact and portable
    Its desktop form factor combined with USB power option makes it a compact and portable solution, ideal for users who need a high-performance scanner that occupies minimal space.
Ricoh fi-65F - flatbed scanner - desktop - USB 2.0
Flatbed scanner - desktop
Interface Type
USB 2.0
Scanning Sensor Type
Contact Image Sensor (CIS)
Light Source
RGB LED array
Max Supported Document Size
A6 (105 x 148 mm)
Input Type
Grayscale / Color Depth
16-bit (64K grey levels)
Grayscale / Color Depth (External)
8-bit (256 grey levels) / 24-bit (16.7 million colours)
Optical Resolution
600 dpi x 600 dpi
Max Document Size
105 mm x 148 mm
Document Feeder Type
Manual
Microsoft Windows Vista (32/64 bits), Microsoft Windows Server 2008 R2 x64 Edition, Microsoft Windows 7 (32/64 bits), Microsoft Windows XP (32/64 bits), Microsoft Windows Server 2008 (32/64-bits), Windows 8 (32/64 bits), Microsoft Windows Server 2012 x64 Edition, Windows 8.1 (32/64 bits), Microsoft Windows Server 2012 R2 x64 Edition, Windows 10 (32/64 bits), Microsoft Windows Server 2016 (64-bit)
14.5 cm x 23.4 cm x 4 cm
900 g
Environmental Standards
ENERGY STAR Qualified
Interface Type
USB 2.0
A6 (105 x 148 mm)
Scanner
Input Type
Grayscale Depth
Grayscale Depth (External)
Colour Depth (External)
Optical Resolution
600 dpi x 600 dpi
Bulb / Light Source Type
RGB LED array
Scanner Speed Details
1.7 sec/scan - portrait colour (AC powered) - 200 dpi , 1 sec/scan - portrait greyscale (AC powered) - A6 - 200 dpi , 1 sec/scan - portrait B&W (AC powered) - A6 - 200 dpi , 1 sec/scan - portrait greyscale (AC powered) - A6 - 300 dpi , 1 sec/scan - portrait B&W (AC powered) - A6 - 300 dpi , 2 sec/scan - portrait colour (USB bus powered) - 200 dpi , 2 sec/scan - portrait greyscale (USB bus powered) - A6 - 200 dpi , 2 sec/scan - portrait B&W (USB bus powered) - A6 - 200 dpi , 2 sec/scan - portrait greyscale (USB bus powered) - A6 - 300 dpi , 2 sec/scan - portrait B&W (USB bus powered) - A6 - 300 dpi
Scanner Features
Powered by USB port
TWAIN, ISIS
Media Handling
Max Document Size
105 mm x 148 mm
Manual
Interfaces Details
USB 2.0 - Type B
1 x USB cable
RoHS
ENERGY STAR Certified
External power adapter
Power Consumption Operational (Standby)
8 Watt (2 Watt)
Software Included
Software Operation Panel, PaperStream IP, PaperStream Capture
14.5 cm
23.4 cm
4 cm
900 g
5 °C
35 °C
20 - 80% (non-condensing)
C38V Fujitsu Extends Warranty From 1 Year to 3 Year For Passport Scanners - Inc Replacement and Shipping In Stock £70.44
