Fujitsu fi-7460 Duplex Document Scanner
Quicklinx: C38KWS00 Mfr#: PA03710-B051
Type: Document scanner
Form Factor: Desktop
Max Paper Size: 304.8 x 431.8 mm
Interface: USB 3.0
Compatibility: PC
  • Windows 8 (32/64 bits)
  • Windows 8.1 (32/64 bits)
£1,839.19 ex VAT
£2,207.02 inc VAT
The fi-7460 is easy to set up, use and maintain and comes bundled with a user friendly and intuitive scanner driver PaperStream IP along with batch scanning automation and enhancement software PaperStream Capture. A4 landscape scanning speeds in both color or black and white at up to 300 dpi is 60 pages per minute or 120 images per minute through the 100 page capacity ADF. The fi-7460 can scan a huge variety of material from plastic cards to booklets to even folded A1 in size.
The fi-7460 scanner comes with a unique paper protection function that is based on acoustic sensors; iSOP (Intelligent Sonic Paper Protection), iSOP reduces the risk of having documents damaged by sensing the audible noise of paper movements and stopping the feeding of sheets when an irregular noise is encountered.
The scanner additionally makes use of an ultrasonic sensor that accurately detects multifeed errors where two or more sheets are fed through the scanner at once plus intelligent multifeed function that is designed for documents that intentionally feature paper attachments of defined sizes or locations such as sticky notes or photos. The scanner can automatically recognize the location of the attachment and will then exclude that zone from triggering alert conditions.
Skew Reducer helps ensure straight paper feeding, should you be scanning mixed batches of differing thicknesses of documents then the "skew reducer" eliminates the risk of physical skew being carried over from one sheet in a mixed batch to the next ensuring that each document is captured with the utmost precision and simplicity. Multi-segmented pick rollers that rotate independently ensure that if a document goes through skewed then this will not affect the alignment of the next document.
Integrated within the operating panel a backlight enhanced LCD shows useful information such as current scanner settings, operating status and a paper counter, in addition the fi-7460 comes with Scanner Central Admin tools that includes functions that system administrators can use to manage the installation and operation of multiple scanners, monitor operation status and update drivers and software from one location. This ability dramatically reduces the cost and work that goes into setting up, operating and maintaining many scanners in an organization and also in expanding the scanner network to multiple locations.
The fi-7460 comes bundled with PaperStream IP, an integrated scanner driver and image enhancement module that is built on TWAIN/ISIS standards offering user friendly operability, intuitive high quality image creation and real time processing that will benefit post scan routines like OCR. PaperStream Capture enhances the document capture process from adjusting scanning settings to performing batch scanning, verifying data and releasing to directories, repositories or subsequent process routines. Users can complete data capture tasks easily with the extremely user-friendly graphical user interface (GUI). Moving scanned batches into a queue for later retrieval is possible as well.
  • Efficient duplex scanning
    The Ricoh fi-7460 enhances productivity with its automatic duplex scanning capability, allowing for fast double-sided scanning without manual intervention.
  • Versatile document handling
    This scanner is equipped to handle a wide range of document sizes, from standard A4 to long documents up to 304.8 x 5588 mm, making it ideal for various scanning needs.
  • High-speed performance
    Achieve scanning speeds of up to 60 ppm in color, grayscale, and black and white, with duplex modes reaching up to 120 ipm, ensuring quick processing of large scanning volumes.
  • Advanced image processing
    Features like Advanced DTC, Blank Page Detection, and Ultrasonic Multi Feed Detection ensure high-quality scans with minimal errors, enhancing the efficiency of document processing workflows.
  • Energy-efficient design
    ENERGY STAR certification and a low power consumption design during operation and sleep modes underscore the fi-7460's commitment to environmental sustainability.
Ricoh fi-7460 - document scanner - desktop - USB 3.0
Document scanner - desktop
Interface Type
USB 3.0
Scanning Sensor Type
Dual CCD
Light Source
White LED array
Max Supported Document Size
304.8 x 431.8 mm
Input Type
Grayscale / Color Depth (External)
8-bit (256 grey levels) / 24-bit (16.7 million colours)
Optical Resolution
600 dpi x 600 dpi
Interpolated Resolution
1200 dpi x 1200 dpi
Max Document Scan Speed
60 ppm (mono) / 60 ppm (colour)
Max Document Size
304.8 mm x 5588 mm
Automatic Duplexing
Supported Document Type
Plain paper, plastic card
Document Feeder Type
Manual, automatic
Document Storage Capacity
100 sheets
AC 120/230 V
Microsoft Windows Vista (32/64 bits), Microsoft Windows Server 2008 R2 x64 Edition, Microsoft Windows 7 (32/64 bits), Microsoft Windows Server 2008 (32/64-bits), Windows 8 (32/64 bits), Microsoft Windows Server 2012 x64 Edition, Windows 8.1 (32/64 bits), Microsoft Windows Server 2012 R2 x64 Edition, Windows 10 (32/64 bits), Microsoft Windows Server 2016 (64-bit)
38 cm x 20.9 cm x 16.8 cm
7.6 kg
Environmental Standards
ENERGY STAR Qualified
Interface Type
USB 3.0
304.8 x 431.8 mm
Scanner
Input Type
Grayscale Depth (External)
Colour Depth (External)
Optical Resolution
600 dpi x 600 dpi
1200 dpi x 1200 dpi
Automatic Duplexing
Dual CCD
Bulb / Light Source Type
White LED array
Max Document Scan Speed B/W
60 ppm
Max Document Scan Speed Colour
60 ppm
Scanner Speed Details
60 ppm - landscape colour - A4 - 200 dpi , 60 ppm - landscape colour - A4 - 300 dpi , 60 ppm - landscape greyscale - A4 - 200 dpi , 60 ppm - landscape greyscale - A4 - 300 dpi , 60 ppm - landscape B&W - A4 - 200 dpi , 60 ppm - landscape B&W - A4 - 300 dpi , 120 ipm - duplex - landscape colour - A4 - 200 dpi , 120 ipm - duplex - landscape colour - A4 - 300 dpi , 120 ipm - duplex - landscape greyscale - A4 - 200 dpi , 120 ipm - duplex - landscape greyscale - A4 - 300 dpi , 120 ipm - duplex - landscape B&W - A4 - 200 dpi , 120 ipm - duplex - landscape B&W - A4 - 300 dpi , 50 ppm - portrait colour - A4 - 200 dpi , 50 ppm - portrait colour - A4 - 300 dpi , 50 ppm - portrait greyscale - A4 - 200 dpi , 50 ppm - portrait greyscale - A4 - 300 dpi , 50 ppm - portrait B&W - A4 - 200 dpi , 50 ppm - portrait B&W - A4 - 300 dpi , 100 ipm - duplex - portrait colour - A4 - 200 dpi , 100 ipm - duplex - portrait colour - A4 - 300 dpi , 100 ipm - duplex - portrait greyscale - A4 - 200 dpi , 100 ipm - duplex - portrait greyscale - A4 - 300 dpi , 100 ipm - duplex - portrait B&W - A4 - 200 dpi , 100 ipm - duplex - portrait B&W - A4 - 300 dpi
Scanner Features
Multi Color Dropout, Image Emphasis, Long Paper Mode, Dynamic Threshold, Error Diffusion, automatic colour detection, Dither, Advanced DTC, Multi-Image Output, built-in LCD screen, Ultrasonic Multi Feed Detection, Punch Hole Removal, Deskew, Blank Page Detection, edge cleanup
TWAIN, ISIS
Media Handling
Max Document Size
304.8 mm x 5588 mm
Supported Document Size Details
ADF - up to 304.8 x 431.8 mm , Long document - up to 304.8 x 5588 mm
Manual, automatic
100 sheets
Interfaces Details
USB 3.0
1 x USB cable
RoHS
ENERGY STAR Certified
External power adapter
AC 120/230 V
Power Consumption Operational (Standby)
36 watt
Power Consumption Stand by
0.35 watt
Power Consumption Sleep
1.4 watt
Software Included
Drivers & Utilities, ScanSnap Manager, ABBYY FineReader for ScanSnap, Scanner Central Admin, Software Operation Panel, PaperStream IP, PaperStream Capture
38 cm
20.9 cm
16.8 cm
7.6 kg
5 °C
35 °C
20 - 80% (non-condensing)
C38K Fujitsu Extends Warranty From 1 Year to 3 Year For Department Scanners- Inc Replacement and Shipping In Stock £172.59
C38K Fujitsu Extends Warranty to 3 Years On-Site Fix for Departmental Scanners - Onsite Within 8 Hours In Stock £523.03
Interface: USB 3.0
Compatibility: PC
Brand: Fujitsu
Price Range Ex VAT: £1500+
