Advanced scanning intelligence, high reliability, increased productivity: The fi-6750S professional production scanner.
Transform your paper documents into useful electronic data in a flash with the intelligent scanning features of the fi-6750S production scanner. Designed with outstanding paper handling, high scan speeds of up to 72ppm and intelligent productivity enhancement features, the fi-6750S scanner delivers the automation and dependability needed for production scanning applications. The fi-6750S's innovative intelligent multi-feed function drastically improves the batch scanning process by allowing the ultrasonic double-feed detection sensor to be trained to ignore intentional overlapping documents such as photos, label stickers, or taped-on receipts.
The PaperStream IP driver takes the work out of image cleanup when scanning invoices, ID cards, receipts, forms, or any other day to day paperwork. PaperStream IP automatically improves the image quality, removes unwanted backgrounds, and optimizes your scanned images for optical character recognition. It is fast and easy to use. The latest innovation, Assisted Scan, allows users to replace poor images by visually selecting the image they lack rather than learning driver settings. If driver settings need to be adjusted for rare and difficult documents, the preview function allows scan operators to see their adjustments in real-time without time consuming re-scans. PaperStream IP works with both ISIS and TWAIN applications.
PaperStream Capture makes advanced capture with Fujitsu scanners easier than before. PaperStream Capture has a streamlined User Interface to reduce training time and increase productivity. Not only have Fujitsu provided users with the most common profiles used by customers - black and white, color, and auto-color - new profiles are easily created or modified through a wizard. Fujitsu has organized the release screen so that batches can easily be suspended or continued. PaperStream Capture is also integrated with PaperStream IP's assisted scanning for visual cleanup of documents. The reading of barcodes and patch codes make batch separation easy, improving document organization.
Whether the infrastructure is fixed or expanding, managing technology efficiently inside the organization is key to reducing total cost of ownership and the Fujitsu scanner provides system administrators with advanced software tools to centrally manage the scanner more productively and cost effectively.
In keeping with Fujitsu's long-standing commitment to safeguarding the environment, the fi-6750S is the latest business scanner to adhere to strictest ecological regulations throughout the entire manufacturing process. The design and manufacture of the fi-6750S meet Energy Star's energy consumption requirements and the European Union's Reduction of Hazardous Substances and Volatile Organic Compounds regulations.
Intelligent multi-feed function
The intelligent multi-feed function simplifies pre-scanning preparation and improves efficiency by ignoring documents that tend to trigger false multi-feed alerts, such as photo and sticky note attached documents. -
Trapezoid-shaped and tab attached document cropping/punch hole removal functionality
In addition to being loaded with a function that ensures that trapezoid-shaped documents as well as index tab and sticky note attached documents are scanned in their entirety, the fi-6750S supports a function that removes the circular and angular punch hole representations that are created from scanning loose-leaf sheets, courier service forms and other similar documents.
- Fujitsu fi-6750S - document scanner - desktop - USB 2.0
- Document scanner - desktop
- Interface Type
- USB 2.0
- Scanning Sensor Type
- CCD
- Max Supported Document Size
- ANSI B (Ledger) (279 x 432 mm)
- Input Type
- Grayscale / Color Depth
- 10-bit grey
- Grayscale / Color Depth (External)
- 8-bit (256 grey levels) / 24-bit (16.7 million colours)
- Optical Resolution
- 600 dpi x 600 dpi
- Max Document Scan Speed
- 72 ppm (mono) / 72 ppm (colour)
- Max Document Size
- 279 mm x 3048 mm
- Supported Document Type
- Plain paper
- Document Feeder Type
- Automatic
- Document Storage Capacity
- 200 sheets
- Duty Cycle
- 8000 scans per day
- Power
- AC 120/230 V (50/60 Hz)
- System Requirements
- Microsoft Windows Vista (32/64 bits), Microsoft Windows Server 2008 R2 x64 Edition, Microsoft Windows 7 (32/64 bits), Microsoft Windows XP (32/64 bits), Microsoft Windows Server 2008 (32/64-bits), Windows 8 (32/64 bits), Microsoft Windows Server 2012 x64 Edition, Windows 8.1 (32/64 bits), Microsoft Windows Server 2012 R2 x64 Edition, Windows 10 (32/64 bits)
- 69 cm x 50 cm x 34.2 cm
- 35 kg
- Environmental Standards
- ENERGY STAR Qualified
- Interface Type
- USB 2.0
Scanner
- Input Type
- Grayscale Depth
- 10-bit grey
- Grayscale Depth (External)
- Colour Depth (External)
- 24-bit (16.7 million colours)
- 600 dpi x 600 dpi
- CCD
- Max Document Scan Speed B/W
- 72 ppm
- Max Document Scan Speed Colour
- 72 ppm
- Duty Cycle
- Scanner Features
- Intelligent Multi-Feed Function (iMFF), Paper Protection Function
- TWAIN, ISIS
Media Handling
- Max Document Size
- 279 mm x 3048 mm
- Plain paper
- Automatic
- 200 sheets
- USB 2.0 - Type B
- RoHS
- ENERGY STAR Certified
- Power Device
- Internal power supply
- Voltage Required
- Power Consumption Operational (Standby)
- 216 Watt (6 Watt)
- Software Included
- ScanSnap Manager, Scanner Central Admin, Software Operation Panel, PaperStream IP, PaperStream Capture
- OS Required
- 69 cm
- 50 cm
- 34.2 cm
- 35 kg
- 5 °C
- 35 °C
- 20 - 80%
