Product
Fujitsu fi-6670 Document Scanner
Quicklinx: 99DLWS00 Mfr#: PA03576-B661
  • Windows 8 (32/64 bits)
  • Windows 8.1 (32/64 bits)
Transform your paper documents into useful electronic data in a flash with the intelligent scanning features of the Fujitsu fi-6670 production level scanner. Designed with outstanding paper handling, high scan speeds up to 90ppm / 180ipm and intelligent productivity enhancement features, the Fujitsu fi-6670 scanner delivers the automation and dependability needed for production scanning applications. The Fujitsu fi-6670's intelligent multi-feed function drastically improves the batch scanning process by allowing the ultrasonic double-feed detection sensor to be trained to ignore intentional overlapping documents, including photos, label stickers, or taped-on receipts. The Fujitsu fi-6670 color scanner comes additionally bundled with PaperStream IP and PaperStream Capture for enhanced batch processing and image enhancement.
True to Fujitsu's commitment to environmentally responsible manufacturing and design, the fi-6670 business scanner adheres to strict environmental regulations including Energy Star's energy consumption requirements and the EU's Reduction of Hazardous Substances and Volatile Organic Compounds.
  • Intelligent, reliable production scanning for a more productive work environment
    Transform your paper documents into useful electronic data in a flash with the intelligent scanning features of the Fujitsu fi-6670 production scanner. Designed with outstanding paper handling, high scan speeds up to 90ppm / 180ipm and intelligent productivity enhancement features, the Fujitsu fi-6670 scanner delivers the automation and dependability needed for production scanning applications. The Fujitsu fi-6670's intelligent multi-feed function drastically improves the batch scanning process by allowing the ultrasonic double-feed detection sensor to be trained to ignore intentional overlapping documents, including photos, label stickers, or taped-on receipts.
  • High-impact imaging solutions, low environmental impact
Fujitsu fi-6670 - document scanner - desktop - USB 2.0, SCSI
Document scanner - desktop
Interface Type
USB 2.0, SCSI
Scan Element Type
CCD
Max Supported Document Size
ANSI B (Ledger) (279 x 432 mm)
Input Type
Grayscale / Color Depth
10-bit grey
Grayscale / Color Depth (External)
8-bit (256 grey levels) / 24-bit (16.7 million colours)
Optical Resolution
600 dpi x 600 dpi
Max Document Scan Speed
90 ppm (mono) / 90 ppm (colour)
Max Document Size
279 mm x 432 mm
Automatic Duplexing
Supported Document Type
Plain paper
Document Feeder Type
Automatic
Document Storage Capacity
200 sheets
Duty Cycle
15000 scans per day
Microsoft Windows Vista (32/64 bits), Microsoft Windows 7 (32/64 bits), Microsoft Windows XP (32/64 bits), Microsoft Windows Server 2008 (32/64-bits), Windows 8 (32/64 bits), Microsoft Windows Server 2008 R2 (64-bits), Windows 8.1 (32/64 bits), Microsoft Windows Server 2012 (64-bit), Microsoft Windows Server 2012 R2 (64-bit), Windows 10 (32/64 bits)
30 cm x 17 cm x 30 cm
17 kg
Environmental Standards
ENERGY STAR Qualified
Interface Type
USB 2.0, SCSI
Scanner
Input Type
Grayscale Depth
10-bit grey
Grayscale Depth (External)
Colour Depth (External)
Optical Resolution
600 dpi x 600 dpi
Automatic Duplexing
Scan Element Type
CCD
Max Document Scan Speed B/W
90 ppm
Max Document Scan Speed Colour
90 ppm
Duty Cycle
15000 scans per day
Scanner Speed Details
90 ppm - black & white , 90 ppm - colour , 180 ipm - duplex - black & white , 180 ipm - duplex - colour
Scanner Features
Ultrasonic Double Feed Detection
TWAIN, ISIS
Media Handling
Max Document Size
279 mm x 432 mm
Plain paper
Automatic
200 sheets
Ultra SCSI - HD-68 , USB 2.0 - Type B
EPEAT Compliant
EPEAT Silver
ENERGY STAR Certified
Internal power supply
Power Consumption Operational (Standby)
216 Watt (6 Watt)
Software Included
ScanSnap Manager, Scanner Central Admin, Software Operation Panel, PaperStream IP, PaperStream Capture
30 cm
17 cm
30 cm
17 kg
5 °C
35 °C
20 - 80%
Sound Emission
53 dB
99DL Fujitsu Print Cartridge In Stock £62.67
