Synology RS2421RP+ 12 Bay Rackmount Enclosure NAS
Quicklinx: G9Z7WS00 Mfr#: RS2421(RP)+
Type: NAS server
Controller Type: RAID
£2,105.60 ex VAT
£2,526.72 inc VAT
Synology RS2421+/RS2421RP+ are versatile 2U 12-bay storage servers designed to accommodate a diverse set of business environments. Scalable up to 24 drives, they are designed for cost-effective file management and sharing and include powerful backup capabilities designed for businesses with a growing data footprint. The unit delivers 2,200 MB/s 64K sequential read and 1154 MB/s sequential write performance1, and can be optionally enhanced with SSD cache and 10/25Gb Ethernet2.
Built for reliability
Redundant power3-
Reduce the possibility of power disruptions on a single distribution channel or PDU adversely impacting data and service availability.
Near-zero downtime-
Pair two identical devices with Synology High Availability and enable automatic minute-level failover between both devices in the event one server fails.
Data integrity and protection-
ECC memory brings higher system reliability, while the Btrfs file system helps prevent data corruption, supports snapshot technology, and simplifies data protection.
  • Versatile and reliable storage platform
    RS2421RP+ units combine ample performance with versatile storage capabilities to deliver a cost-efficient data management solution.
  • Optimized for data protection and integrity
    Powered by Synology's DSM operating system, tailored for data management, and built upon the Btrfs file system, data stored on the S2421RP+ is safely guarded by modern data protection technologies.
  • Remote and on-premises collaboration
    Synology's collaboration suite provides a private cloud solution for on-premises and remote workers to concurrently edit documents, share files, manage emails, send instant messages, and more.
  • Private video surveillance
    With Synology surveillance station, the RS2421RP+ become powerful network video recorder solutions with support for up to 40 IP cameras.
  • Virtualization and certified storage
    DSM streamlines provisioning for and management of virtual machines with full certification for VMware vSphere, Microsoft Hyper-V, Citrix XenServer, and OpenStack virtualization environments.
Synology RackStation RS2421RP+ - NAS server
NAS server
Host Connectivity
Gigabit Ethernet
Enclosure Type
Rack-mountable - 2U
Max Supported Capacity
108 TB
0 (installed) / 12 (max)
48.2 cm x 57.8 cm x 8.8 cm
11.9 kg ()
1 x Ryzen Embedded V1500B 2.2 GHz (Quad-Core)
Storage Controller
RAID SATA 6Gb/s RAID RAID 0, 1, 5, 6, 10, JBOD
10Mb LAN, 100Mb LAN, 1GbE
IP Cameras Supported
40
RAM
4 GB
Power Redundancy
Microsoft Windows 7, Apple macOS 10.12
3-year warranty
NAS server
Host Connectivity
Gigabit Ethernet
Enclosure Type
Rack-mountable - 2U
Total Storage Capacity
0 GB
108 TB
48.2 cm
57.8 cm
8.8 cm
11.9 kg ()
Processor / Memory
Processors Installed
Number of Cores
Quad-Core
Max Supported Qty
1
RAM
4 GB (installed) / 32 GB (supported) - DDR4
Storage Controller
RAID
Interface Type
SATA 6Gb/s
RAID Level
RAID 0, RAID 1, RAID 5, RAID 6, RAID 10, JBOD
Network / Transport Protocol
PPTP, L2TP, iSCSI, FTP, SMB, NFS, SFTP, HTTPs
Remote Management Protocol
SNMP, Telnet, HTTPS, SSH, SFTP
Network Services Compatibility
Network File System (NFS), FTP, Server Message Block (SMB), Apple File Protocol (AFP), Web-based Distributed Authoring and Versioning (WebDAV), Calendaring Extensions to WebDAV (CalDAV), SFTP
VPN support, LDAP support, Access Control List (ACL) support, SSH support, e-mail server, reset button, Rsync compatible, L2TP support
Encryption Algorithm
SSL, TLS, AES-NI
Security DVR
40
Expansion Bays
12 (total) / 12 (free) x hot-swap - 2.5" / 3.5"
Expansion Slots
1 (total) / 1 (free) x PCI Express
4 x Ethernet 1000Base-T , 2 x USB 3.2 - Type A , 1 x management
Built-in 3 cooling fans
TLS, SSL
Internal power supply
Installed Qty
2
Max Supported Qty
2
Power Redundancy
Limited warranty - 3 years
35 °C
5 - 95%
G9Z7 Synology DDR4 - module - 4 GB for RS2421+, RS2421RP+, RS2821RP+ In Stock £122.62
Type: NAS server
Brand: Synology
Price Range Ex VAT: £1500+
