Increase your Synology NAS performance with this Synology D4EU01-4G 4GB DDR4 ECC UDIMM RAM module.
Built and designed for maximum performance and reliability in Synology devices.
Compatible with:
- RS2821RP+
- RS2421RP+
- RS2421+
Enhanced reliability
Equipped with ECC (Error Correcting Code) to detect and correct internal data corruption, this 4 GB DDR4 SDRAM memory module offers enhanced reliability for your Synology system. -
Seamless compatibility
Designed specifically for Synology systems, this DIMM 288-pin memory module ensures seamless compatibility and a straightforward upgrade process, enhancing system performance without the hassle. -
Optimized performance
With unbuffered storage, this memory module provides faster data transfer and lower latency, making it ideal for improving the overall performance of your Synology system.
- Synology - DDR4 - module - 4 GB - DIMM 288-pin - unbuffered
- Product Type
- Memory module
- Capacity
- 4 GB
- Memory Type
- DDR4 SDRAM - DIMM 288-pin
- Upgrade Type
- System specific
- Data Integrity Check
- ECC
- Unbuffered
- OEM Manufacturer Equivalent Part Number
- Synology D4EU01-4G
- Designed For
- RackStation RS2421+, RS2421RP+, RS2821RP+
- Capacity
- 4 GB
- Upgrade Type
- System specific
- DRAM memory module
- Technology
- DDR4 SDRAM
- Form Factor
- DIMM 288-pin
- ECC
- Unbuffered
- Designed For
- Synology RackStation RS2421+, RS2421RP+, RS2821RP+
