Synology RS3621xs+ 12 Bay Rackmount Enclosure
Quicklinx: G595WS00 Mfr#: RS3621XS+
Type: Rackmount Kit
Controller Type: RAID
  • Xeon
Hurry, only 2 left in stock!
£3,431.11 ex VAT
£4,117.33 inc VAT
The 12-bay RS3621xs+ is capable of delivering over 238K 4K random read IOPS and 5,819 MB/s sequential read throughput1— a true enterprise powerhouse. With full power supply redundancy, an 8-core processor, ECC memory, advanced snapshot technology, and file self-healing, the RS3621xs+ provides a reliable foundation to any data-driven business.
  • Accelerate your business operations
    The 12-bay RS3621xs+ is a true enterprise powerhouse. With full power supply redundancy, an 8-core processor, ECC memory, advanced snapshot technology, and file self-healing, the RS3621xs+ provides a reliable foundation to any data-driven business.
  • Storage you can trust
    The RS3621xs+ keeps your data protected while you concentrate on delivering great results to your customers - even when disaster strikes.
  • Redundant power
    Dual PSUs provide protection against a PSU failure or accidental cord removal while hot-swappable fans allow them to be replaced without powering down the system.
  • Maximize service availability
    Synology High Availability (SHA) pairs two identical units together creating an active-passive cluster with minute-level failover.
  • Next-generation file system
    Btrfs prevents data corruption and reduces maintenance overheads with advanced storage technologies and optimized snapshots.
  • Tailored to your business
    The RS3621xs+ includes two PCIe slots for performance, networking, and storage upgrades enabling it to adapt to any business environment.
  • Hyper Backup
    A comprehensive backup and recovery solution for securing data stored on Synology servers. Backup data locally, to another Synology device, rsync server, or cloud-based storage such as Google Drive, Dropbox, S3-compatible destinations, and Synology C2. Deduplication, integrity checks, and incremental transfer technology reduce bandwidth and storage use.
  • Snapshot replication
    Easily schedule flexible point-in-time backups of shared folders and iSCSI LUNs with an RPO as low as 5 minutes and recovery in seconds. Set up replication and failover to other Synology storage systems for fast RTOs and minimal service disruption.
  • Active backup suite
    Enables administrators to easily backup the entire IT infrastructure to their NAS, including Windows and Linux workstations and servers, file servers, VMware and Hyper-V virtual machines, and Microsoft 365 and Google Workspace accounts. Backups benefit from deduplication, multiversioning, and optimizations to reduce bandwidth and storage used.
Synology RackStation RS3621xs+ - NAS server
NAS server
Host Connectivity
Gigabit Ethernet / 10 Gigabit Ethernet
Enclosure Type
Rack-mountable - 2U
0 (installed) / 12 (max)
48.2 cm x 72.4 cm x 8.8 cm
14.5 kg ()
1 x Intel Xeon D-1541 2.1 GHz (8-core)
Storage Controller
RAID SATA 6Gb/s RAID 0, 1, 5, 6, 10, JBOD, RAID F1, 1 hot spare, 10 hot spare, 5 hot spare, 6 hot spare, F1 hot spare
1GbE, 10GbE
RAM
8 GB
Power Redundancy
5-year warranty
NAS server
Host Connectivity
Enclosure Type
Rack-mountable - 2U
Total Storage Capacity
0 GB
48.2 cm
72.4 cm
8.8 cm
14.5 kg ()
Processor / Memory
Processors Installed
Number of Cores
8-core
Max Supported Qty
1
Max Turbo Speed
2.7 GHz
RAM
8 GB (installed) / 64 GB (supported) - DDR4
Storage Controller
RAID
Interface Type
SATA 6Gb/s
RAID Level
RAID 0, RAID 1, RAID 5, RAID 6, RAID 10, JBOD, RAID F1, RAID 1 hot spare, RAID 10 hot spare, RAID 5 hot spare, RAID 6 hot spare, RAID F1 hot spare
1GbE, 10GbE
Network / Transport Protocol
PPTP, L2TP, iSCSI, SMTP, FTP, DHCP, POP3, IMAP
Remote Management Protocol
SNMP, Telnet, HTTPS
Network Services Compatibility
Microsoft Active Directory (AD), Network File System (NFS), Server Message Block (SMB), Apple File Protocol (AFP), Web-based Distributed Authoring and Versioning (WebDAV), Calendaring Extensions to WebDAV (CalDAV)
Firewall protection, VPN support, LDAP support, VLAN support, wake on LAN (WOL), print server, antivirus analysis, High Availability, web server, backup server, file sharing, event log, Access Control List (ACL) support, iTunes server, DHCP server, FTP server, BitTorrent Client, e-mail server, bandwidth control, surveillance station, eMule client, e-mail notification
Encryption Algorithm
256-bit AES
DLNA CERTIFIED
Expansion Bays
12 (total) / 12 (free) x hot-swap - 2.5" / 3.5"
Expansion Slots
2 (total) / 2 (free) x PCI Express 3.0 x8 , 4 (total) / 3 (free) x DIMM 288-pin
4 x Ethernet 1000Base-T - RJ-45 , 2 x USB 3.2 Gen 1 - Type A , 2 x Ethernet 10Gb - RJ-45 , 2 x expansion port , 1 x management
FCC, BSMI, VCCI, RCM, EAC, CCC, KC, UL, RoHS
Accessory pack
Internal power supply
Installed Qty
2
Max Supported Qty
2
Power Redundancy
Power Redundancy Scheme
1+1
142.5 Watt
Power Provided
500 Watt
Limited warranty - 5 years
35 °C
5 - 95%
Sound Emission
50.2 dBA
Hard Drives
G595 Synology HAT5300-12T 12TB 3.5" SATA HDD In Stock £434.68
G595 Synology 8TB HAS5300 3.5" SAS Hard Drive In Stock £247.92
G595 Synology 12TB HAS5300 3.5" SAS Hard Drive In Stock £347.55
Type: Rackmount Kit
Brand: Synology
Price Range Ex VAT: £1500+
