Synology RS3621RPxs is a powerful 12-bay storage server. Its 6-core processor enables compute-intensive services while its redundant power, ECC memory, and Btrfs file system safeguard mission-critical data. Capable of delivering 189,098 4K random read IOPS and 4,718 MB/s sequential read throughput, it is ideal for small businesses.
Redundant power
Dual PSUs provide protection against a PSU failure or accidental cord removal while hot-swappable fans can be replaced without powering down the system. -
Near-zero downtime
Synology High Availability (SHA) pairs two identical units together creating an active-passive cluster with minute-level failover. -
Next-generation file system
Btrfs prevents data corruption and reduces maintenance overheads with advanced storage technologies and optimized snapshots. -
Customize to suit
The two built-in PCIe slots allow users to customize RS3621RPxs to satisfy unique performance, networking, and storage requirements.
- Synology RackStation RS3621RPxs - NAS server
- NAS server
- Host Connectivity
- Gigabit Ethernet
- Enclosure Type
- Rack-mountable - 2U
- Installed Devices / Modules Qty
- 0 (installed) / 12 (max)
- 48.2 cm x 72.4 cm x 8.8 cm
- 14.5 kg ()
- Processor
- 1 x Intel Xeon D-1531 2.2 GHz (6-core)
- Storage Controller
- RAID SATA 6Gb/s RAID 0, 1, 5, 6, 10, JBOD, RAID F1, 1 hot spare, 10 hot spare, 5 hot spare, 6 hot spare, F1 hot spare
- Networking
- 1GbE
- RAM
- 8 GB
- Power
- AC 120/230 V (50/60 Hz)
- Power Redundancy
- 5-year warranty
- NAS server
- Host Connectivity
- Gigabit Ethernet
- Enclosure Type
- Total Storage Capacity
- 0 GB
- 48.2 cm
- 72.4 cm
- 8.8 cm
- 14.5 kg ()
Processor / Memory
- Processors Installed
- Number of Cores
- 6-core
- Max Supported Qty
- 1
- Max Turbo Speed
- 2.7 GHz
- RAM
- 8 GB (installed) / 64 GB (supported) - DDR4
Storage Controller
- RAID
- Interface Type
- SATA 6Gb/s
- RAID Level
- RAID 0, RAID 1, RAID 5, RAID 6, RAID 10, JBOD, RAID F1, RAID 1 hot spare, RAID 10 hot spare, RAID 5 hot spare, RAID 6 hot spare, RAID F1 hot spare
- Data Link Protocol
- 1GbE
- PPTP, L2TP, iSCSI, SMTP, FTP, DHCP, POP3, IMAP
- Remote Management Protocol
- SNMP, Telnet, HTTPS
- Network Services Compatibility
- Microsoft Active Directory (AD), Network File System (NFS), Server Message Block (SMB), Apple File Protocol (AFP), Web-based Distributed Authoring and Versioning (WebDAV), Calendaring Extensions to WebDAV (CalDAV)
- Firewall protection, VPN support, LDAP support, VLAN support, WOL, print server, antivirus analysis, High Availability, web server, backup server, file sharing, event log, ACL support, iTunes server, DHCP server, FTP server, BitTorrent Client, e-mail server, bandwidth control, surveillance station, eMule client, e-mail notification
- Encryption Algorithm
- 256-bit AES
- DLNA CERTIFIED
- Expansion Bays
- 12 (total) / 12 (free) x hot-swap - 2.5" / 3.5"
- Expansion Slots
- 2 (total) / 2 (free) x PCI Express 3.0 x8 , 4 (total) / 3 (free) x DIMM 288-pin
- 4 x Ethernet 1000Base-T - RJ-45 , 2 x USB 3.2 Gen 1 - Type A , 2 x expansion port , 1 x management
- FCC, BSMI, VCCI, RCM, EAC, CCC, KC, UL, RoHS
- Included Accessories
- Accessory pack
- Power Device
- Internal power supply
- Installed Qty
- 2
- Max Supported Qty
- 2
- Power Redundancy
- Power Redundancy Scheme
- 1+1
- Voltage Required
- 140.01 Watt
- Power Provided
- 500 Watt
- Limited warranty - 5 years
- 0 °C
- 35 °C
- 5 - 95%
- Sound Emission
- 50.2 dBA
Hard Drives
Synology HAT5300-12T 12TB 3.5" SATA HDD | In Stock | £429.27 |
