Synology RX2417SAS 24 Bay Rack Mountable
Quicklinx: FWJYWS00 Mfr#: RX2417SAS
Type: Hard drive array
Controller Type: RAID
£2,490.20 ex VAT
£2,988.24 inc VAT
Effortless capacity expansion for Synology FlashStation and RackStation solutions on-the-fly.
Easily add 24 additional drive bays to Synology FlashStation or RackStation. Supporting 2.5" SAS/SATA drives, the RX2417sas is a flexible solution supporting on-the-fly volume expansion or serving as a local backup destination.
Dual power supplies ensure continuous service uptime. Easily replace defective drives with the hot swappable drive trays.
  • 24-bay 2.5" SAS/SATA expansion
  • Maximum reliability design
Synology RX2417sas - hard drive array
Hard drive array
Enclosure Type
Rack-mountable - 2U
SAS
0 (installed) / 24 (max)
Supported Drives
SATA-600 / SAS
Storage Controller
RAID (SATA 6Gb/s / SAS)
Hard Drive
No HDD - hot-swap
AC 120/230 V - 50/60 Hz
Power Redundancy
48.2 cm x 72.4 cm x 8.8 cm
16.6 kg
5-year warranty
Hard drive array
Enclosure Type
Rack-mountable - 2U
Chassis
0
Supported Devices / Modules Qty
24
Supported Drives
SATA-600 / SAS
Storage
HDD Array External Interface
SAS
CPU
No CPU
Storage Controller
RAID
Channel Qty
24
Interface Type
SATA 6Gb/s / SAS
Hard Drive
No HDD - hot-swap
Expansion Bays
24 (total) / 24 (free) x hot-swap - 2.5"
1 x SAS (input) , 1 x SAS (output)
1 x mini SAS HD cable
FCC Class A certified, RoHS, BSMI Class A
2 x internal power supply
Max Supported Qty
2
Power Redundancy
201.6 Watt
Power Provided
500 Watt
48.2 cm
72.4 cm
8.8 cm
16.6 kg
Limited warranty - 5 years
5 °C
35 °C
5 - 95%
Sound Emission
60.8 dBA
Brand: Synology
Price Range Ex VAT: £1500+
