Synology SA3200D 12 Bay Rack Mountable
Quicklinx: FWK5WS00 Mfr#: SA3200D
Type: Rackmount Kit
Controller Type: RAID
  • Xeon
£6,206.38 ex VAT
£7,447.65 inc VAT
Synology SA3200D features a dual controller architecture to ensure operations and core business functions are not severely impacted by a disaster or unplanned incident that take critical systems offline. The hardware redundancy mechanism leverages controllers, power supplies, and fans to prevent a single point of failure. Powered by the intuitive and feature-rich operating system DiskStation Manager (DSM), SA3200D provides comprehensive protection for network, file services, and applications.
  • Designed with high availability and scalability
    Synology SA3200D is a cost-effective yet highly available data management solution for enterprises. Underneath the 2U chassis are dual controller modules in an active-passive architecture, each connected to the other by the reliable, high-speed Non-Transparent Bridge (NTB) with low latency. Service continuity is also backed up by the hardware redundancy mechanism of modularized power supplies and fans to prevent a single point of failure.
  • Real-time protection with automatic failover
    With an active-passive design consisting of dual controller modules and the built-in Synology High Availability (SHA) service, SA3200D is built to provide a real-time, system-level protection to maximize service availability. It actively monitors network status and critical file services of CIFS, iSCSI, AFP, FTP, NFS, and Synology Directory Server.
  • Easy to deploy, easy to manage
    SA3200D is designed to help IT administrators easily deploy and manage a highly available data management infrastructure. The system features straightforward, wizard-based GUI setup processes that allow you to build up a highly available service environment within minutes. Service status monitoring is made easy and intuitive.
  • Virtualize workloads flexibly in a protected environment
    Synology Virtual Machine Manager (VMM) is an intuitive hypervisor software application allowing you to easily set up virtual machines and run various operating systems, including Windows, Linux, and Virtual DSM. By integrating the computing and the storage nodes into one system, single vendor support experience is achieved to lower the management cost.
Synology SA3200D - NAS server
NAS server
Host Connectivity
Gigabit Ethernet / 10 Gigabit Ethernet
Enclosure Type
Rack-mountable - 2U
Max Supported Capacity
192 TB
0 (installed) / 12 (max)
48.2 cm x 72.4 cm x 8.8 cm
19.7 kg ()
2 x Intel Xeon D-1521 2.4 GHz (Quad-Core)
Storage Controller
RAID RAID 0, 1, 5, 6, 10, JBOD, RAID F1
10Mb LAN, 100Mb LAN, 1GbE, 10GbE
IP Cameras Supported
100
RAM
16 GB
Microsoft Windows 7 or later, Apple MacOS X 10.11 or later
5-year warranty
NAS server
Host Connectivity
Enclosure Type
Rack-mountable - 2U
Total Storage Capacity
0 GB
192 TB
48.2 cm
72.4 cm
8.8 cm
19.7 kg ()
Processor / Memory
Processors Installed
Number of Cores
Quad-Core
Max Supported Qty
2
Max Turbo Speed
2.7 GHz
RAM
16 GB (installed) / 128 GB (supported) - DDR4
ECC
Storage Controller
RAID
RAID Level
RAID 0, RAID 1, RAID 5, RAID 6, RAID 10, JBOD, RAID F1
Network / Transport Protocol
PPTP, L2TP, iSCSI, SMTP, FTP, SMB, NFS, HTTPs
Remote Management Protocol
SNMP, Telnet, HTTPS, SSH, SMTP, LDAP
Network Services Compatibility
Microsoft Active Directory (AD), Network File System (NFS), FTP, Server Message Block (SMB), Apple File Protocol (AFP), HTTPS, Web-based Distributed Authoring and Versioning (WebDAV), Calendaring Extensions to WebDAV (CalDAV)
Firewall protection, VPN support, LDAP support, WOL, antivirus analysis, High Availability, download client, anti-malware protection, ACL support, e-mail server, reset button, bandwidth control, surveillance station, VPN Server, Link Aggregation, failover protection, DLNA support, OpenStack compatible, Btrfs, file station, EXT4 file system, iSCSI LUN clone/snapshot, Windows ODX, MailPlus server
Encryption Algorithm
AES-NI
Security DVR
100
Compression Format
H.264
Expansion Bays
12 (total) / 12 (free) x hot-swap - 2.5" / 3.5"
Expansion Slots
2 x PCI Express 3.0 x8
4 x Ethernet 1000Base-T - RJ-45 , 2 x serial - DB-9 , 2 x Ethernet 10Gb - RJ-45
Built-in 4 cooling fans
VCCI, BSMI, CCC, FCC, RoHS, EAC, RCM
Accessory pack
Internal power supply
Installed Qty
2
Max Supported Qty
2
417.48 Watt
Power Provided
500 Watt
Limited warranty - 5 years
35 °C
5 - 95%
Sound Emission
51.3 dBA
Hard Drives
FWK5 Synology 8TB HAS5300 3.5" SAS Hard Drive In Stock £235.53
FWK5 Synology 12TB HAS5300 3.5" SAS Hard Drive In Stock £358.13
Type: Rackmount Kit
Brand: Synology
Price Range Ex VAT: £1500+
