Dim or brighten the room, toggle light scenes, or get the best light based on the time of day. The Hue dimmer switch attaches to walls or magnetic surfaces, but can also be used as a remote control anywhere in your home.
Control lights instantly
Get instant control over your Philips Hue smart lights with the Hue dimmer switch. With the touch of a button, your entire household can instantly dim or brighten the room, turn lights on and off, or set light scenes.
Easy, wireless installation
Transform your space with accents of coloured light. You can dim down the intensity and blend soft colour tones for smooth light effects, making this lamp perfect for parties as well as quiet evenings at home.
Set scenes with the touch of a button
Pair your Philips Hue Iris limited edition lamp with the Hue Bridge to unlock wake up and go to sleep routines, which help you fall asleep and wake up more naturally. The lamp’s dimming capabilities paired with its diffused backlight allow you to wake up to your own personal sunrise in the morning as your lights gently brighten, or gradually dim warm white lights to help you drift off to sleep easier.
Unlock more with the Hue Bridge
Pair the Hue dimmer switch with a Hue Bridge to control any lights, rooms, or zones in your home – no matter where the switch is located – and customise the switch however you like. Once connected, you'll experience the full potential of this smart light and can use the Philips Hue app to control it from your smart phone or tablet. Set timers, notifications, alarms and more for the full Philips Hue experience. Philips Hue even works with Amazon Alexa, Apple HomeKit, and the Google Assistant to allow you to control your lights with your voice.
Get instant control over your Philips Hue smart lights with the Hue dimmer switch. With the touch of a button, your entire household can instantly dim or brighten the room, turn lights on and off, or set light scenes. -
The battery-powered, wireless design of the Hue dimmer switch lets you mount it anywhere with the included adhesive tape. Remove the switch from its wall plate and use it as a remote control or attach it to any magnetic surface. -
Switch between the four preset light recipes, Read, Relax, Energize and Concentrate, by pressing the Hue button.
- Philips Hue - wireless lighting dimmer - white
- Product Type
- Wireless lighting dimmer
- White
- Platform
- Hue
- Communications Technology
- Zigbee
- Product Type
- Android compatible, iOS compatible, magnetic, battery operated, up to 50000 switch cycles
- 1 x CR2032
Internet of Things (IoT)
- Platform
- Hue
- Compatible Application
- Philips Hue App
- Zigbee
- Product Material
- Plastic
- Body Colour
- White
- Included Accessories
- Adhesive tape, battery, wall mount
- IP20
- Warranty
- 2 years
- Dimensions & Weight Details
- Wall plate - width: 8 cm x depth: 1.5 cm x height: 12.5 cm
- Shipping Dimensions (WxDxH) / Weight
- 9 cm x 5.8 cm x 17 cm / 170 g
- 0 °C
- 40 °C
