Philips Hue Lily Outdoor Spotlight Base Kit with Bridge Starter Kit
Quicklinx: H4Z7WS00 Mfr#: 919313000064
Type: Spot light
Compatible With: Alexa
Hurry, only 2 left in stock!
£308.33 ex VAT
£369.99 inc VAT
Turn your garden into your own little oasis with these Philips outdoor spotlights. You can turn them on or off from your phone and as the sun’s going down, you can even turn the brightness up as well. Since there’re 16 million shades to choose between, go bold for that dinner party or enjoy a warm glow when you’re getting stuck into a good book. Fancy lights at the front of the house instead? The timer lets you schedule them to turn on automatically for when you arrive home. With a 25,000-hour lifespan, you can keep on enjoying that warm welcome for a long time to come.
Please note, to use the Philips Hue light bulb you’ll need a Philips Bridge (included). You’ll also need to download the free Philips Hue app, which is compatible with all iOS and Android devices.
  • Smart spotlight can be wirelessly controlled
  • White and coloured bulb – choose from 16 million shades
  • Standalone light with a 25,000 hour lifespan
  • Schedule a timer to turn lights on automatically
  • Dim the brightness to match your mood
  • Beautiful spotlights
    Enhance your outdoor space and create the right atmosphere for any occasion with Lily spotlights.
  • Millions of colors of light
    Use millions of shades of white or colored light to highlight outdoor features, such as trees or fountains, and create a unique atmosphere for any occasion.
  • Powerful light output
    Shine bright, focused light on any object in your garden to give it the attention it deserves.
  • Flexibility at its finest
    Lily spotlights adapt to their surroundings, adding a pop of color anywhere in your garden - no matter how your outdoor space is designed.
  • Simple to install
    With the LowVolt technology, you can plug your outdoor lights into the included low-voltage adapter - no complicated wiring required.
  • Versatile mounting options
    Use Lily spotlights however you like - mount high up on a post for downlighting, nestle into the flower bed to highlight a garden or shine light up through the branches of a tree for a unique look.
  • Easy to extend
    Add more Lily spotlights to your set-up with an easy-to-use T-connector, one of the features of the LowVolt system.
Philips Hue White and Color Ambiance Lily - spot light - LED - 8 W - 16 million colours - 2000-6500 K - black (pack of 3)
Spot light
Recommended For
Garden, patio
Light Source Type
LED
Packaged Quantity
3 (specifications are for single item)
Dimmer
Wattage
8 W
Energy Efficiency Class
G
Colour of Illumination
16 million colours
Colour Temperature
2000-6500 K
Luminous Power
1770 lumens
Platform
Hue
AC 220 - 240 V
Frequency Required
50 - 60 Hz
Packaged Quantity
Spot light
Recommended For
Garden, patio
Dimmer
Double insulated, extendable, LowVolt, preset modes
Light Source
LED
Built-in LED Lamp
Wattage
8 W
G
Energy Consumption per 1000h
0.5 kWh
16 million colours
Colour Temperature
2000-6500 K
Colour Rendering Index
80
Luminous Power
1770 lumens
Lifetime
25000 hours
Light scheduling
Power Requirements
AC 220 - 240 V
Frequency Required
50 - 60 Hz
Internet of Things (IoT)
Hub
Included
Hub Compatibility
Philips Hue Bridge
Platform
Hue
Product Material
Aluminium
Body Colour
Network cable
IP65
Warranty
2 years
7 cm
8.4 cm
19.4 cm
3.18 kg
Type: Spot light
Brand: Philips
