Philips Hue Play Lightbar 2-Pack with Bridge Starter Kit
Quicklinx: H50QWS00 Mfr#: 919313000068
Type: Light bar
Compatible With: Alexa, Google Assistant
15 In Stock
£141.66 ex VAT
£169.99 inc VAT
Whether it’s blockbusters or dramatic game backdrops, don’t just enjoy those cinematic scenes on your screen, be surrounded by them with the Philips Hue Play light bar. It’ll flood your room with colour, 16 million shades to be precise. You get to decide how bright those hues are since there’s a dimmer switch on the app, and from there you can even use the timer to turn the lights on automatically. Why not schedule them for when you arrive home and enjoy a nice warm welcome each time? Don’t worry about it ending any time soon either, the standalone light has a 25,000-hour lifespan.
Please note, to use the Philips Hue light bulb you’ll need a Philips Bridge (included). You’ll also need to download the free Philips Hue app, which is compatible with all iOS and Android devices.
  • Smart lightbar can be wirelessly controlled
  • White and coloured bulb – choose from 16 million shades
  • Standalone light with a 25,000 hour lifespan
  • Schedule a timer to turn lights on automatically
  • Dim the brightness to match your mood
  • Sync with films, TV programs, music and games
    Get dynamic surround lighting right in your living room.
  • Set the mood with light
    Create a color ambiance that perfectly matches your mood and home interior.
  • Place it anywhere
    Use the included stands to set the light bars upright or mount them to the TV - or just lay them flat!
  • Small but mighty
    The Play light bar enhances any entertainment set-up.
Philips Hue White and Color Ambiance Play - light bar - LED - 13.2 W - 16 million colours - 2000-6500 K - black (pack of 2)
Light bar
Recommended For
Living room
Light Source Type
LED
Packaged Quantity
2 (specifications are for single item)
Dimmer
Wattage
13.2 W
Colour of Illumination
16 million colours
Colour Temperature
2000-6500 K
Luminous Power
500 lumens
Intelligent Assistant
Google Assistant, Alexa - indirect
Platform
SmartThings
Communications Technology
Zigbee
Packaged Quantity
Light bar
Recommended For
Living room
Dimmer
Expandable, music sync, timer function
Light Source
LED
Built-in LED Lamp
Wattage
13.2 W
16 million colours
Colour Temperature
2000-6500 K
Luminous Power
500 lumens
Internet of Things (IoT)
Hub
Included
Hub Compatibility
Philips Hue Bridge
Platform
SmartThings
Supported Host Device Platform
iOS, Android
Zigbee
Voice Controlled
Indirect
Body Colour
Stand
IP20
Warranty
2 years
4.4 cm
3.6 cm
Length
25.3 cm
710 g
Type: Light bar
Brand: Philips
