Experience the thrill of the cinema at home with the Philips Hue Play gradient lightstrip. Get multiple colors of light that react to the content on your screen.
A halo of reactive light
Step into your character's world with a brilliantly colorful, boldly immersive gaming experience. -
Bring your games to life
Get a seamless gradient of rich, high-quality light. Each color along the lightstrip flows naturally into one another, creating a unique effect. The Hue Play gradient lightstrip for PC mounts to the back of your single- or triple-monitor setup, bending easily around its corners. -
Easy to install
The Hue Play gradient lightstrip for PC comes in three sizes for single- and triple-monitor setups, and includes mounting clips, making it easy to attach to the back of your monitor. -
Blend multiple colors of light
Colors flow naturally into one another, blending together and shining against the wall for a unique effect behind your monitor.
- Philips Hue Play Gradient - light strip - LED - 15 W - 2000-6500 K - black
- Product Type
- Light strip
- Light Source Type
- LED
- Light Cover Type
- Diffuser
- Dimmer
- Black
- Wattage
- 15 W
- Colour Temperature
- 2000-6500 K
- Luminous Power
- 800 lumens
- Beam Angle
- 45 degree(s)
- Platform
- Hue
- Voltage Required
- AC 220 - 240 V
- Product Type
- Light strip
- Light Cover Type
- Diffuser
- Dimmer
- Double insulated, iOS compatible, diffused light effect, Windows compatible, app-controlled, Hue Sync technology, 24" - 27" monitor compatible
Light Source
- LED
- Built-in LED Lamp
- Wattage
- 15 W
- 2000-6500 K
- Luminous Power
- 800 lumens
- Beam Angle
- 45 degree(s)
- Lifetime
- 25000 hours
Power Requirements
- Voltage Required
- AC 220 - 240 V
- Power Consumption Stand by
- 0.5 Watt
Internet of Things (IoT)
- Internet of Things (IoT) Compatible
- Hub Compatibility
- Philips Hue Bridge
- Platform
- Hue
- Compatible Application
- Philips Hue App, Philips Hue Sync app
- Product Material
- Silicone
- Body Colour
- Black
- Included Accessories
- Power adapter, mounting brackets, plug
- IP20
- Warranty
- 2 years / 30 days return
- 1.7 cm
- 1.6 cm
- Length
- 90.5 cm
- 203 g
- Shipping Dimensions (WxDxH) / Weight
- 29 cm x 29 cm x 14 cm / 1.13 kg
- -20 °C
- 45 °C
