Philips Hue White Ambiance Bulbs 2-Pack B22 8W
Quicklinx: GX0PWS00 Mfr#: 929002468502
Type: Light bulb
Compatible With: Alexa, Google Assistant, Cortana
12 In Stock
£41.66 ex VAT
£49.99 inc VAT
Use thousands of shades of warm-to-cool white light with these B22 smart bulbs, whose bayonet bases fit most standard fixtures. Wireless dimming lets you set the right mood instantly.
  • Set the right mood with warm to cool white light
    These bulbs and light fixtures offer different shades of warm to cool white light. With complete dimmability from bright to low nightlights, you can tune your lights to the perfect shade and brightness of light for your daily needs.
  • Control up to 10 lights with the Bluetooth app
    With the Hue Bluetooth app, you can control your Hue smart lights in a single room of your home. Add up to 10 smart lights and control them all with just the touch of a button on your mobile device.
  • Control lights with your voice
    Philips Hue works with voice assistants when paired with a compatible device. Simple voice commands allow you to control multiple lights in a room, or just a single lamp.
  • Get the perfect light recipes for your daily activities
    Make your day easier and more pleasant with four pre-set light recipes handcrafted especially for your daily tasks: Energize, Concentrate, Read and Relax. The two cool-toned scenes, Energize and Concentrate, help you get going in the morning or keep your focus, while the warmer scenes of Read and Relax help support comfortable reading or calm a busy mind.
Philips Hue White ambiance 1100 - LED light bulb - shape: A60 - B22 - 11 W - warm white to cool white light - 2200-6500 K (pack of 2)
Light Source Type
LED light bulb
Packaged Quantity
2 (specifications are for single item)
Shape
A60
Socket Type
B22
Wattage
11 W
Energy Efficiency Class
F
Colour of Illumination
Warm white to cool white light
Colour Temperature
2200-6500 K
Luminous Power
1055 lumens
Dimmable
Intelligent Assistant
Cortana, Google Assistant, Alexa - indirect
Platform
Apple HomeKit
Communications Technology
Bluetooth, Zigbee
AC 220 - 240 V
Packaged Quantity
Light Source
LED light bulb
Shape
A60
Socket Type
B22
Wattage
11 W
F
Energy Consumption per 1000h
11 kWh
Power Factor
0.5
Colour Temperature
2200-6500 K
Colour Rendering Index
80
Luminous Power
1055 lumens
Dimmable
Lifetime
25000 hours
Switch Cycles
50000
Instant on, upgradable software
Power Requirements
AC 220 - 240 V
Power Consumption Stand by
0.5 Watt
Internet of Things (IoT)
Hub Compatibility
Philips Hue Bridge
Platform
Apple HomeKit
Supported Host Device Platform
iOS, Android
Bluetooth, Zigbee
Voice Controlled
Indirect
Warranty
2 years / 30 days return
Diameter
60 mm
Length
110 mm
72 g
14.6 cm x 7.2 cm x 17.4 cm / 270 g
-20 °C
45 °C
Type: Light bulb
Compatible With: Cortana
Brand: Philips
