The Philips Hue White and Color Ambiance light bulb offers versatility through its multicolor capability, allowing users to customize their lighting for any occasion. Compatible with various intelligent assistants such as Alexa, Google Assistant, and Apple HomeKit, this bulb provides seamless integration into existing smart home systems. With a light output of 400 lumens and a color temperature range of 2000-6500 K, it ensures both vibrant colors and warm whites, perfect for enhancing the atmosphere in any room. Designed with energy efficiency in mind, the bulb operates at just 4.2 W while providing a wattage equivalent of 50 W. It boasts a long lifetime of 25,000 hours, along with 50,000 switch cycles, making it a reliable choice for energy-conscious consumers. The Philips Hue App allows for personalized control, enabling users to dim the light and adjust colors with ease. This bulb is a functional lighting solution and a stylish addition to any living space.
Innovative smart technology
The Philips Hue White and Color Ambiance light bulb is IoT-compatible, enabling control through various intelligent assistants like Cortana and Apple HomeKit, integrating into smart home ecosystems. -
Versatile lighting options
This bulb offers a wide color temperature range from warm white to daylight, allowing for customization in lighting ambiance across different settings in the home. -
Energy-efficient design
Operating at just 4.2 W while producing 400 lumens, the Philips Hue bulb provides significant energy savings while retaining excellent performance. -
Long-lasting performance
With a rated lifetime of 25,000 hours and capable of enduring 50,000 switch cycles, this light bulb is designed for durability and reduces the need for frequent replacements.
- Philips Hue White and Color Ambiance - LED spot light bulb - GU10 - 4.2 W - multicolour/cold white/warm white to daylight - 2000-6500 K (pack of 3)
- Light Source Type
- Packaged Quantity
- 3 (specifications are for single item)
- Socket Type
- GU10
- Wattage
- 4.2 W
- Wattage Equivalent
- 50 W
- Energy Efficiency Class
- E
- Colour of Illumination
- Multicolour/cold white/warm white to daylight
- Colour Temperature
- 2000-6500 K
- Luminous Power
- 400 lumens
- Beam Angle
- 40 degree(s)
- Dimmable
- Intelligent Assistant
- Cortana, Google Assistant, Alexa, Apple HomeKit
- Platform
- Hue
- Light Source Voltage
- AC 220-240 V
- Packaged Quantity
Light Source
- Socket Type
- GU10
- Wattage
- 4.2 W
- 50 W
- E
- Energy Consumption per 1000h
- 5 kWh
- Power Factor
- 0.5
- 2000-6500 K
- Colour Rendering Index
- 80
- Luminous Power
- 400 lumens
- Beam Angle
- 40 degree(s)
- Dimmable
- Lifetime
- 25000 hours
- Switch Cycles
- 50000
Power Requirements
- AC 220-240 V
- 4.2 Watt
- Power Consumption Stand by
- 0.25 Watt
Internet of Things (IoT)
- Internet of Things (IoT) Compatible
- Hub Compatibility
- Philips Hue Bridge
- Platform
- Hue
- Compatible Application
- Philips Hue App
- Package
- Box
- 50 mm
- 57 mm
- Diameter
- 50 mm
- Length
- 50 mm
- 50 g
- Shipping Dimensions (WxDxH) / Weight
- 7.2 cm x 7.2 cm x 17.4 cm / 190 g
Used stock
What is used stock?
Accessories | Packaging | Functional | Software | Manuals | ||
Ref:
J1D0 051364 Condition: Customer return - item has been opened but is in excellent condition |
£70.94 |
Legend
This part of the stock item is present and in good condition
This part of the stock item is not present or functional
This part of the stock item is damaged in some way. This damage may not render this part of the stock unusable.
This part of the stock item is not applicable e.g. it might not include accessories or software as standard
This item has not been tested.
