Philips Hue Lily Base Unit 3-Pack Spot Light - Black
Quicklinx: GNVWWS00 Mfr#: 915005630101
Type: Spot light
Compatible With: Alexa, Google Assistant, Siri
£216.66 ex VAT
£259.99 inc VAT
Extend your evenings with Philips Hue outdoor lighting. Set the right ambiance on your patio, balcony or porch and relax. From the warm white light of a summer sun, to the ice cool daylight of winter: you can enjoy any shade of white light to fit your mood throughout the year.
  • Weather-proof design
    This Philips Hue outdoor fixture is specially designed for use in outdoor environments and has undergone rigorous tests to ensure its performance.
  • Set timers for your convenience
    Enjoy longer evenings outside, finish gardening or just put the rubbish outside after sunset. Have your Philips Hue lights turn on automatically by setting schedules or use the sunset/sunrise routine.
  • High-quality aluminum and superior synthetics
    The products are made specifically for outdoor use. Quality materials are used to ensure better performance in the outdoor conditions as well as smart use of materials to optimize radio frequency.
Philips Hue White and Color Ambiance Lily - spot light - LED - 8 W - 16 million colours - 2000-6500 K - black (pack of 3)
Spot light
Light Source Type
LED
Packaged Quantity
3 (specifications are for single item)
Dimmer
Cable Length
0.5 m
Wattage
8 W
Wattage Equivalent
49 W
Energy Efficiency Class
G
Colour of Illumination
16 million colours
Colour Temperature
2000-6500 K
Luminous Power
600 lumens
Intelligent Assistant
Siri, Google Assistant, Alexa
Platform
Apple HomeKit, Google Home
AC 220 - 240 V
Frequency Required
50 - 60 Hz
Packaged Quantity
Spot light
Dimmer
Cable Length
0.5 m
Double insulated, outdoor usage, remote controlled, tiltable, dustproof, waterproof
Light Source
LED
Built-in LED Lamp
Wattage
8 W
Wattage Equivalent
49 W
G
Energy Consumption per 1000h
8 kWh
16 million colours
Colour Temperature
2000-6500 K
Luminous Power
600 lumens
Lifetime
25000 hours
Power Requirements
AC 220 - 240 V
Frequency Required
50 - 60 Hz
Internet of Things (IoT)
Hub Compatibility
Philips Hue Bridge
Platform
Product Material
Aluminium
Body Colour
Plug, power supply
IP65
Warranty
2 years
7 cm
8.4 cm
19.4 cm
Length
8.4 cm
3.18 kg
31 mm x 23.5 cm x 22.3 cm / 3.74 kg
Type: Spot light
Compatible With: Siri
Brand: Philips
