The 136 column ML5721eco dot matrix printer delivers fast, reliable multi-part forms printing and low running costs. A high 700cps (characters per second) print speed, fast throughput and ability to manage heavy medias make it perfect for demanding environments such as vehicle repair/service centers, warehouses, factories, wholesalers and freight forwarders.
Ideal for high duty applications, printing receipts, invoices, picking lists, reports and wide format spreadsheets, on single or multi-part paper, the ML5721eco printer will keep productivity levels high. And with multiple emulations built-in, replacing old printers is simple and straightforward.
- OKI Microline 5721eco - printer - monochrome - dot-matrix
- Printer Type
- Workgroup printer - dot-matrix - 9 pin - monochrome
- 10 kg
- Max Media Size
- Continuous paper 76.2 mm - 406.4 mm (width)
- Min Media Size (Custom)
- 76.2 mm x 76.2 mm
- Max Media Size (Custom)
- 406.4 mm x 558.8 mm
- Print Speed
- Up to 700 char/sec - super speed draft , Up to 600 char/sec - high speed draft , Up to 600 char/sec - high speed draft , Up to 600 char/sec - high speed draft , Up to 600 char/sec - high speed draft , Up to 600 char/sec - high speed draft , Up to 450 char/sec - draft , Up to 450 char/sec - draft , Up to 450 char/sec - draft , Up to 450 char/sec - draft , Up to 431 char/sec - draft , Up to 113 char/sec - near letter , Up to 113 char/sec - near letter , Up to 113 char/sec - near letter , Up to 108 char/sec - near letter , Up to 108 char/sec - near letter
- Interface
- Parallel, USB
- RAM Installed (Max)
- 128 KB
- Language Simulation
- EPSON FX, IBM PPR, Okidata Microline
- Barcodes
- Matrix 2 of 5, Industrial 2 of 5, Code 39, NW-7, EAN/JAN-8, EAN/JAN-13, UPC-A, UPC-E, Interleaved 2 of 5, Postnet, OCR-B, Code 128B, Code 128C, Code 128A
- Media Type
- Envelopes, labels, plain paper, continuous forms, cards, fanfold paper
- Power
- AC 230V
- System Requirements
- Microsoft Windows 2000, Microsoft Windows Vista (32/64 bits), Microsoft Windows Server 2008 R2 x64 Edition, Microsoft Windows 7 (32/64 bits), Microsoft Windows XP (32/64 bits), Microsoft Windows Server 2008 (32/64-bits), Microsoft Windows Server 2003 (32/64-bits)
- 3 years warranty with product registration
- 59.2 cm x 37.5 cm x 19.1 cm
- Printer Type
Printer
- Print Speed
- Up to 700 char/sec - super speed draft - 12 cpi , Up to 600 char/sec - high speed draft - 10 cpi , Up to 600 char/sec - high speed draft - 12 cpi , Up to 600 char/sec - high speed draft - 15 cpi , Up to 600 char/sec - high speed draft - 17.1 cpi , Up to 600 char/sec - high speed draft - 20 cpi , Up to 450 char/sec - draft - 10 cpi , Up to 450 char/sec - draft - 12 cpi , Up to 450 char/sec - draft - 15 cpi , Up to 450 char/sec - draft - 20 cpi , Up to 431 char/sec - draft - 17.1 cpi , Up to 113 char/sec - near letter - 10 cpi , Up to 113 char/sec - near letter - 12 cpi , Up to 113 char/sec - near letter - 15 cpi , Up to 108 char/sec - near letter - 17.1 cpi , Up to 108 char/sec - near letter - 20 cpi
- Connectivity Technology
- Wired
- Interface
- Parallel, USB
- Fonts Included
- 1 x scalable , 1 x barcode
- Barcodes
RAM
- 128 KB
Media Handling
- Media Type
- Max Media Size
- 76.2 mm x 76.2 mm
- Media Sizes
- Media Feeders
- 1 x manual - 1 sheet - continuous paper 76.2 mm - 406.4 mm (width)
- Max Sheets in Multi-Part Form
- 7
- Connections
- 1 x parallel , 1 x USB - 4 pin USB Type B
- Consumables Included
- 1 x printhead - up to 400 million characters , 1 x ribbon - up to 13 million characters
- MTBF
- 25,000 hour(s)
- Power Device
- Power supply - internal
- Voltage Required
- AC 230V
- Frequency Required
- 50/60 Hz
- 52 Watt
- Power Consumption Stand by / Sleep
- 1.5 Watt
- Software Included
- OKI LPR, OKI Status Monitor, OKI Network Set Up
- OS Required
Environmental Standards
- ENERGY STAR
- Limited warranty - 3 years
- Sound Emission (Operating)
- 57 dBA
- Sound Emission (Quiet Mode)
- 52 dBA
- 59.2 cm
- 37.5 cm
- 19.1 cm
- 10 kg
