OKI B432DN A4 Mono Laser Printer
Quicklinx: C8BRWS00 Mfr#: 45858302
  • Windows 8 (32/64 bits)
  • Windows 8.1 (32/64 bits)
If you need a black & white printer that supports extremely high levels of office productivity, without straining your budget, you need the B432dn.
  • A printer for every office
    The combination of highly productive print speeds, excellent fine detail image quality for crisp, clear documents, and a design that complements working environments make the B432dn the perfect printer for every office.
  • Exceptionally easy to use
    Automatic two-sided printing; a LCD display, a low profile design for easier document retrieval: the B432dn will keep office productivity at a maximum, whether you choose the B432dn for fast personal printing or for sharing on the network.
  • Impressive print speeds
    The B432dn races through large jobs in minimal time. The first page prints out in 4.5 seconds and the rest at an impressive 40 pages per minute.
  • Use it all day, every day
    True 1200x1200dpi resolution means that all of your everyday office documents are printed with fine, crisp detail. An extra paper supply can be added, increasing the capacity right the way up to 880 and there is also a 100-sheet multi-purpose paper tray for feeding a variety of different paper types and sizes.
  • Compact and efficient
    The B432dn is specifically designed to meet the demands of offices. This unusually compact printer will fit in any office where space is limited. The toner cartridge and drum are separate units so you only ever have to replace what needs replacing so there’s no waste.
  • Extra value
    Other essential features include automatic two-sided printing as standard and a 2-line LCD display that tells you all about the current operating status of your printer. Sharing is made easy with Gigabit Ethernet or the optional wireless interface, while confidential documents are protected with PIN release secure print.
  • Built for endurance
    The B432dn uses ultra-reliable digital LED technology with fewer moving parts for exceptional durability.
OKI B432dn - printer - B/W - LED
Printer Type
Workgroup printer - LED - B/W
12 kg
United Kingdom
Media Size Class
A4/Legal
Max Media Size
210 x 1321 mm
Max Media Size (Custom)
210 mm x 1321 mm
Print Speed
Up to 40 ppm - B/W
Max Resolution (B&W)
1200 x 1200 dpi
Automatic Duplexing
USB 2.0, Gigabit LAN
667 MHz
RAM Installed (Max)
512 MB
Flash Memory Installed (Max)
3 GB
Language Simulation
PCL 5E, PostScript 3, PCL 6, IBM ProPrinter, XPS, PDF 1.7
Barcodes
Code 39, UCC/EAN-128, QR code, EAN/JAN-8, EAN/JAN-13, UPC-A, UPC-E, Codabar, Code 128, Interleaved 2 of 5, Postnet, PDF417, OCR-A, OCR-B, ZIP
Total Media Capacity
350 sheets
Media Handling
250-sheet input tray, 100-sheet bypass tray
Monthly Duty Cycle (max)
80000 pages
Recommended Monthly Volume
500 - 5000 pages
Print server
Linux, Microsoft Windows Vista (32/64 bits), Microsoft Windows Server 2008 R2 x64 Edition, Microsoft Windows 7 (32/64 bits), Microsoft Windows Server 2008 (32/64-bits), Microsoft Windows Server 2003 (32/64-bits), Apple MacOS X Lion 10.7, Apple MacOS X 10.6.8, Apple OS X 10.8 Mountain Lion, Windows 8 (32/64 bits), Microsoft Windows Server 2012 x64 Edition, Windows 8.1 (32/64 bits), Microsoft Windows Server 2012 R2, Apple OS X 10.9 Mavericks, Microsoft Windows Server 2012 R2 x64 Edition
3-year warranty with product registration
24.5 cm x 38.7 cm x 36.4 cm
Printer Type
Workgroup printer - LED - monochrome
United Kingdom
Printer
Print Speed
Up to 40 ppm - B/W
Built-in Devices
Status LCD
Wired
1200 x 1200 dpi
Automatic Duplexing
First Print Out Time B/W
4.5 sec
Language Simulation
Fonts Included
87 x PCL , 136 x PostScript , 2 x bitmapped , 1 x barcode
Barcodes
Media Handling
667 MHz
RAM
RAM Installed (Max)
512 MB
Flash Memory
Flash Memory
3 GB
Media Handling
Media Size Class
A4/Legal
Max Media Size
210 x 1321 mm
210 mm x 1321 mm
Media Sizes
ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), Executive (184 x 267 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), A6 (105 x 148 mm), Statement (139.7 x 215.9 mm)
Envelope Sizes
International DL (110 x 220 mm), International C6 (114 x 162 mm), Com-10 (105 x 241 mm), International C5 (162 x 229 mm), Monarch (98.4 x 190.5 mm), Com-9 (98 x 225 mm)
350 sheets
Media Feeders
1 x automatic - 100 sheets weight: 60 g/m² - 163 g/m² , 1 x automatic - 250 sheets weight: 60 g/m² - 105 g/m²
Max Media Capacity
880 sheets
Duty Cycle
80000 pages
500 - 5000 pages
Print server
Remote Management Protocol
SNMP 1, SNMP 3, IPP, HTTP, HTTPS, IPPS
Security Protocols & Features
IPsec
1 x USB 2.0 - 4 pin USB Type B , 1 x LAN - RJ-45
Power supply - internal
Frequency Required
50/60 Hz
600 Watt
Power Consumption Stand by
80 Watt
Power Consumption Sleep
1.4 Watt
Limited warranty - 3 years
10 °C
32 °C
20 - 80% (non-condensing)
Sound Emission (Idle)
30 dBA
Sound Emission (Operating)
55 dBA
24.5 cm
38.7 cm
36.4 cm
12 kg
