OKI Microline 3391eco Mono Dot-Matrix Printer
Quicklinx: CQ53WS00 Mfr#: 01308503
The Microline 3391 narrow and wide carriage printer is designed for users who require excellent quality and flexibility from a single printer. The Microline 3391 is ideal for volume applications requiring high throughput and flexible changing between various print media. High reliability, ease of use and various in-built barcodes makes this printer the ideal tool for industrial, commercial, service, small business and office environments.
OKI Microline 3391eco - printer - B/W - dot-matrix
Printer Type
Workgroup printer - dot-matrix - 24 pin - B/W
7.6 kg
Max Media Size
Continuous paper 76.2 mm - 406.4 mm (width)
Min Media Size (Custom)
76.2 mm
Max Media Size (Custom)
406.4 mm
Print Speed
Up to 390 char/sec - max speed , Up to 260 char/sec - normal , Up to 312 char/sec - normal , Up to 104 char/sec - near letter , Up to 87 char/sec - near letter
Max Resolution (B&W)
360 dpi
Parallel, USB 2.0
RAM Installed (Max)
128 KB
Language Simulation
IBM AGM, IBM PPR, EPSON LQ
Barcodes
Code 39, EAN/JAN-8, EAN/JAN-13, UPC-A, UPC-E, Interleaved 2 of 5, Postnet, Code 128B, Code 128C, Code 128A
Media Type
Envelopes, labels, plain paper, continuous forms, cards
Microsoft Windows 2000, Microsoft Windows Vista (32/64 bits), Microsoft Windows 7 (32/64 bits), Microsoft Windows XP (32/64 bits), Microsoft Windows Server 2008 (32/64-bits), Microsoft Windows Server 2003 (32/64-bits)
3-year warranty with product registration
55.2 cm x 34.5 cm x 11.6 cm
Printer Type
Workgroup printer - dot-matrix - 24 pin - monochrome
Printer
Print Speed
Up to 390 char/sec - max speed , Up to 260 char/sec - normal - 10 cpi , Up to 312 char/sec - normal - 12 cpi , Up to 104 char/sec - near letter - 12 cpi , Up to 87 char/sec - near letter - 10 cpi
Wired
Parallel, USB 2.0
360 dpi
Language Simulation
Fonts Included
1 x scalable , 1 x barcode
Barcodes
RAM
RAM Installed (Max)
128 KB
Media Handling
Media Type
Max Media Size
76.2 mm
406.4 mm
Media Sizes
Envelope Sizes
Com-10 (105 x 241 mm)
Media Feeders
1 x manual - 1 sheet - continuous paper 76.2 mm - 406.4 mm (width)
Max Sheets in Multi-Part Form
5
1 x parallel - 36 PIN Centronics , 1 x USB 2.0 - 4 pin USB Type B
Consumables Included
1 x printhead - up to 200 million characters , 1 x ribbon - up to 2 million characters
MTBF
10,000 hour(s)
Power supply - internal
Frequency Required
50/60 Hz
30.4 Watt
Environmental Standards
ENERGY STAR
Limited warranty - 3 years
Sound Emission (Operating)
57 dBA
Sound Emission (Quiet Mode)
52 dBA
55.2 cm
34.5 cm
11.6 cm
7.6 kg
