OKI MB 492dn Mono Laser Multifunction Printer
Quicklinx: BV3HWS00 Mfr#: 45858402
Functionality: Scanner, Fax, Copier, Printer
Technology: Laser
Max Paper Size: 210 x 1321 mm
£391.58 ex VAT
£469.89 inc VAT
The MB492dn 4-in-1 multifunction device has the speed, functionality and print quality to meet the needs of more demanding users. This high performance MFP delivers documents fast and incorporates automatic double sided copying, printing, scanning and faxing saving time and paper. The MB492dn is simple to use boasting a 7" LCD color touch screen display, intuitive menu system and enhanced help function. Sharing is easy with Gigabit networking as standard and Oki's ultra-reliable digital LED technology. Reduce your running costs by using extra high capacity toner cartridges, offering you the support for all your current and future business needs.
  • Efficient connectivity
    With a suite of connectivity options including Gigabit Ethernet, USB 2.0, and USB host, alongside AirPrint Enabled for Apple devices, seamless integration into any workspace is easy. Security protocols ensure your documents remain safe with features like 802.1x, IP filtering, and SSL/TLS.
  • Rapid performance
    Experience exceptional speed with up to 40 ppm printing and a first print out time of just 4.5 seconds. Automatic duplexing in printing, copying, and scanning maximizes productivity and efficiency, making it suitable for high-demand environments.
  • Advanced document handling
    The OKI MB 492dn excels in document management with a RADF document feeder, supporting a wide range of media sizes and types including banners and envelopes. With a maximum media capacity of 880 sheets, it meets the needs of busy offices and workgroups.
  • High-quality output
    Achieve sharp, clear documents with a maximum printing resolution of 1200 x 1200 DPI and copying resolution of 600 x 600 DPI. Whether printing or copying, the output is consistently high quality.
  • Comprehensive office solution
    Combining the functions of a copier, fax, printer, and scanner with a recommended monthly volume of 500 - 5000 pages, this device is designed to support the workflows of busy offices. Features like scan to email and scan to FTP enhance its versatility.
OKI MB492dn - multifunction printer - B/W
Multifunction printer
Fax Type
Super G3 - plain paper
Printing Technology
LED (monochrome)
Monthly Duty Cycle (max)
80000 pages
Recommended Monthly Volume
500 - 5000 pages
Max Copying Speed
Up to 37.5 ppm
Max Copying Resolution
Up to 600 x 600 dpi
Max Printing Speed
Up to 40 ppm
Max Printing Resolution
Up to 1200 x 1200 dpi
Max Fax Transmission Speed
33.6 Kbps
Scanning
600 dpi
Display
7"
Original Size
A4 (210 x 297 mm) (max)
Original Type
Sheets
Document Feeder Capacity
50 sheets
Media Size
210 x 1321 mm (max)
Media Type
Envelopes, plain paper, banner
Standard Media Capacity
350 sheets
Max Media Capacity
880 sheets
Bypass Feeder Capacity
100 sheets
Automatic Duplexing
Yes (copying) Yes (printing) Yes (scanning)
Connection Availability
USB 2.0, Gigabit LAN, USB host
AirPrint Enabled
Office Machine Features
Scan to e-mail, scan to folder, scan to FTP
AC 230 V (50/60Hz)
45.5 cm x 42.7 cm x 47.8 cm
21 kg
3-year warranty with product registration
Fax Type
Plain paper
Printing Technology
LED - monochrome
80000 pages
500 - 5000 pages
Display Diagonal Size
7"
AirPrint Enabled
Standard Memory
512 MB
Supported Flash Memory
USB flash drive
Copying
Max Copying Speed
Up to 37.5 ppm
Up to 600 x 600 dpi
Max Document Enlargement
400%
Max Document Reduction
25%
Maximum Copies
99
Automatic Duplexing
Printing
Max Printing Speed
Up to 40 ppm
Printer Drivers / Emulations
PCL 5e, PCL 6, IBM Proprinter, XPS
Automatic Duplexing
First Print Out Time B/W
4.5 sec
Scanning
Automatic Duplexing
Optical Resolution
600 dpi
Colour Depth
24-bit
Colour Depth (Internal)
48-bit
Fax Machine
Compatibility
Super G3
Max Transmission Speed
33.6 Kbps
Total Memory Capacity
Up to 200 pages
Reception Memory Capacity
Up to 200 pages
Fax Machine Features
Speed Dialing
300 station(s)
Broadcast Transmission
100 stations
Document & Media Handling
Max Original Size
A4 (210 x 297 mm)
Original Type
Sheets
50 sheets
Max Media Size
A4
Min Media Weight
60 g/m²
Max Media Weight
163 g/m²
Supported Media Type
Supported Media Sizes
A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), A6 (105 x 148 mm)
Supported Envelope Sizes
International DL (110 x 220 mm), International C6 (114 x 162 mm), Com-10 (105 x 241 mm), International C5 (162 x 229 mm), Monarch (98.4 x 190.5 mm), Com-9 (98 x 225 mm)
350 sheets
Max Media Capacity
880 sheets
100 sheets
Bypass tray - 100 sheets size: A6 (105 x 148 mm) - A4 (210 x 297 mm) weight: 60 g/m² - 163 g/m² , Input tray - 250 sheets size: A6 (105 x 148 mm) - A4 (210 x 297 mm) weight: 60 g/m² - 120 g/m² , RADF - 50 sheets size: A5 (148 x 210 mm) - A4 (210 x 297 mm) weight: 60 g/m² - 105 g/m²
Speed Details
Copying: up to 37.5 ppm - B/W , Printing: up to 40 ppm - B/W , Scanning: 2 sec - B/W , Scanning: 6 sec - colour
1 x USB 2.0 - 4 pin USB Type B , 1 x USB host - 4 pin USB Type A , 1 x LAN - RJ-45
Security Protocols & Features
SSL, TLS, IPsec, 802.1x, IP filtering, MAC address filtering
Operating System Support
Apple Mac OS X 10.7, MS Windows Server 2008 R2 x64 Edition, Apple Mac OS X 10.8, Windows 8, Windows 8 64-bit, Apple Mac OS X 10.6.8, Windows 8.1, Apple Mac OS X 10.9, Windows 8.1 64-bit, MS Windows Server 2012 R2, MS Windows Server 2003 (32/64-bits), MS Windows Server 2008 (32/64-bits), MS Windows Server 2012 R2 x64 Edition, MS Windows Vista (32/64 bits), MS Windows 7 (32/64 bits)
Software Included
OKI Template Manager, OKI LPR, OKI Storage Device Manager, Nuance PaperPort 14, Nuance OmniPage SE 18
AC 230 V (50/60Hz)
630 Watt
Power Consumption Standby
95 Watt
Power Consumption Sleep
1.9 Watt
First Copy Out Time B/W
10 sec
Limited warranty - 3 years
45.5 cm
42.7 cm
47.8 cm
21 kg
Sound Emission
30 dBA (idle) / 55 dBA (operating)
10 °C
32 °C
20 - 80%
BV3H OKI 44574302 Drum In Stock £122.60
BV3H OKI Toner Cartridge Black In Stock £82.31
BV3H OKI Toner Cartridge Black In Stock £119.02
BV3H OKI Toner Cartridge Black In Stock £165.58
Functionality: Fax
Functionality: Copier
Functionality: Printer
Technology: Laser
Brand: OKI
