OKI B412dn (A4) Mono Laser Printer (Networked Duplex) 512MB
Quicklinx: B7L6WS00 Mfr#: 45858301
  • Windows 8 (32/64 bits)
  • Windows 8.1 (32/64 bits)
The B412dn brings productive, high quality black & white printing within the reach of every small business. With OKI, there’s no need to compromise between price and performance. You can have all the productivity features you need in a reliable, robust design that won’t stretch your budget.
  • Minimum expenditure, maximum value
    The combination of the rapid print speeds, fine resolution for crisp, clear documents, and thoughtful design, makes this a printer that everyone will appreciate, whether you choose the B412dn for fast personal printing or for sharing on the network.
  • Designed for ease of use
    Once you start using the B412dn you’ll wonder why other printers aren’t built this way. It has a compact, low profile design, which makes it easy to reach out and pick up your printed documents, a backlit display for clear ‘at a glance’ information about the printer’s current operating status and consumables that anyone can replenish in a matter of moments.
  • Consistent, affordable quality
    The 1200x1200dpi resolution prints clear, pinsharp documents that are sure to impress. You will get full use of each consumable with no unnecessary waste.
  • Extra value
    Other makes of printers in this price range are often rather basic. But the B412dn distinguishes itself by including a range of added value features as standard, such as automatic two-sided printing, a 2-line LCD display and OKI Template Manager for quickly creating and printing on a wide variety of office documents. Sharing is made easy with the Gigabit Ethernet or the optional wireless interface, while confidential documents are protected with PIN release secure print.
  • Built for endurance
    The B412dn uses ultra-reliable digital LED technology with fewer moving parts for exceptional durability.
OKI B412dn - printer - B/W - LED
Printer Type
Workgroup printer - LED - B/W
12 kg
Media Size Class
A4/Legal
Max Media Size
Legal (216 x 356 mm), A4 (210 x 297 mm)
Print Speed
Up to 33 ppm - B/W
Max Resolution (B&W)
1200 x 1200 dpi
Automatic Duplexing
USB 2.0, Gigabit LAN
667 MHz
RAM Installed (Max)
512 MB (512 MB)
Flash Memory Installed (Max)
3 GB
Language Simulation
PCL 5E, PostScript 3, EPSON FX, PCL 6, IBM ProPrinter, XPS, PDF 1.7
Barcodes
Code 39, UCC/EAN-128, QR code, EAN/JAN-8, EAN/JAN-13, UPC-A, UPC-E, Codabar, Code 128, Interleaved 2 of 5, Postnet, PDF417, OCR-A, OCR-B, ZIP
Total Media Capacity
350 sheets
Media Handling
250-sheet input tray, 100-sheet bypass tray
Monthly Duty Cycle (max)
60000 pages
Recommended Monthly Volume
250 - 3000 pages
Print server
Microsoft Windows Vista (32/64 bits), Microsoft Windows Server 2008 R2 x64 Edition, Microsoft Windows 7 (32/64 bits), Microsoft Windows Server 2003 (32/64-bits), Apple MacOS X Lion 10.7, Apple OS X 10.8 Mountain Lion, Windows 8 (32/64 bits), Windows 8.1 (32/64 bits), Microsoft Windows Server 2012 R2, Apple OS X 10.9 Mavericks, Apple MacOS X 10.6.8 - 10.9
3-year warranty with product registration
38.7 cm x 36.4 cm x 24.5 cm
Printer Type
Workgroup printer - LED - monochrome
Printer
Print Speed
Up to 33 ppm - B/W
Built-in Devices
Status LCD
Wired
1200 x 1200 dpi
Automatic Duplexing
First Print Out Time B/W
5 sec
Language Simulation
Fonts Included
87 x PCL
Barcodes
Media Handling
667 MHz
RAM
RAM Installed (Max)
512 MB / 512 MB (max)
Flash Memory
Flash Memory
3 GB
Media Handling
Media Size Class
A4/Legal
Max Media Size
Media Sizes
ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), Executive (184 x 267 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), A6 (105 x 148 mm), Statement (139.7 x 215.9 mm)
Envelope Sizes
International DL (110 x 220 mm), International C6 (114 x 162 mm), Com-10 (105 x 241 mm), International C5 (162 x 229 mm), Monarch (98.4 x 190.5 mm), Com-9 (98 x 225 mm)
Media Weight
60 g/m² - 163 g/m²
350 sheets
Media Feeders
1 x automatic - 100 sheets weight: 60 g/m² - 163 g/m² , 1 x automatic - 250 sheets weight: 60 g/m² - 120 g/m²
Max Media Capacity
880 sheets
Duty Cycle
60000 pages
250 - 3000 pages
Print server
Remote Management Protocol
SNMP 1, SNMP 3, IPP, HTTP, HTTPS, IPPS
1 x USB 2.0 - 4 pin USB Type B , 1 x LAN - RJ-45
Power supply - internal
Frequency Required
50/60 Hz
560 Watt
Power Consumption Stand by
80 Watt
Power Consumption Sleep
1.4 Watt
Limited warranty - 3 years
10 °C
32 °C
20 - 80% (non-condensing)
Sound Emission (Idle)
30 dBA
Sound Emission (Operating)
53 dBA
38.7 cm
36.4 cm
24.5 cm
12 kg
