Brand
OKI MB472dnw Mono Laser Multifunction Printer
Quicklinx: BR15WS00 Mfr#: 45858401
Functionality: Printer, Scanner, Copier, Fax
Output Type: Monochrome
Wireless Capability: Wireless
Technology: Laser
£270.97 ex VAT
£325.16 inc VAT
The compact design of the MB472dnw puts advanced 4-in-1 functionality on the desktop of even the most cost conscious user. This high performance MFP delivers documents fast and incorporates automatic double sided copying, printing, scanning and faxing saving time and paper. The graphic display, intuitive menu system and dedicated function buttons make it easy for everyone in the office to use. The in-built QWERTY keyboard simplifies data and email address entry. Gigabit Ethernet and wireless networking makes sharing easy.
OKI MB472dnw - multifunction printer - B/W
Multifunction printer
Fax Type
Super G3 - plain paper
Printing Technology
LED (monochrome)
Monthly Duty Cycle (max)
60000 pages
Recommended Monthly Volume
250 - 3000 pages
Max Copying Speed
Up to 33 ppm
Max Copying Resolution
Up to 600 x 600 dpi
Max Printing Speed
Up to 33 ppm
Max Printing Resolution
Up to 1200 x 1200 dpi
Max Fax Transmission Speed
33.6 Kbps
Scanning
600 dpi
Display
3.5"
Original Size
A4 (210 x 297 mm) (max)
Original Type
Sheets
Document Feeder Capacity
50 sheets
Media Size
210 x 1321 mm (max)
Media Type
Envelopes, plain paper, banner
Standard Media Capacity
350 sheets
Max Media Capacity
880 sheets
Bypass Feeder Capacity
100 sheets
Automatic Duplexing
Yes (copying) Yes (printing) Yes (scanning)
Connection Availability
USB 2.0, Gigabit LAN, Wi-Fi(n), USB host
AirPrint Enabled
Office Machine Features
Scan to e-mail, scan to folder, scan to FTP
AC 230 V (50/60Hz)
45.5 cm x 42.7 cm x 42.5 cm
20 kg
3-year warranty with product registration
Fax Type
Plain paper
Printing Technology
LED - monochrome
60000 pages
250 - 3000 pages
Display Diagonal Size
3.5"
AirPrint Enabled
Standard Memory
512 MB
Supported Flash Memory
USB flash drive
Copying
Max Copying Speed
Up to 33 ppm
Up to 600 x 600 dpi
Max Document Enlargement
400%
Max Document Reduction
25%
Maximum Copies
99
Automatic Duplexing
Printing
Max Printing Speed
Up to 33 ppm
Printer Drivers / Emulations
PCL 5e, PCL 6, IBM Proprinter, XPS
Automatic Duplexing
First Print Out Time B/W
5 sec
Scanning
Automatic Duplexing
Optical Resolution
600 dpi
Colour Depth
24-bit
Colour Depth (Internal)
48-bit
Fax Machine
Compatibility
Super G3
Max Transmission Speed
33.6 Kbps
Total Memory Capacity
Up to 200 pages
Reception Memory Capacity
Up to 200 pages
Fax Machine Features
Speed Dialing
300 station(s)
Broadcast Transmission
100 stations
Document & Media Handling
Max Original Size
A4 (210 x 297 mm)
Original Type
Sheets
50 sheets
Max Media Size
A4
Min Media Weight
60 g/m²
Max Media Weight
163 g/m²
Supported Media Type
Supported Media Sizes
A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), A6 (105 x 148 mm)
Supported Envelope Sizes
International DL (110 x 220 mm), International C6 (114 x 162 mm), Com-10 (105 x 241 mm), International C5 (162 x 229 mm), Monarch (98.4 x 190.5 mm), Com-9 (98 x 225 mm)
350 sheets
Max Media Capacity
880 sheets
100 sheets
Bypass tray - 100 sheets size: A6 (105 x 148 mm) - A4 (210 x 297 mm) weight: 60 g/m² - 163 g/m² , Input tray - 250 sheets size: A6 (105 x 148 mm) - A4 (210 x 297 mm) weight: 60 g/m² - 120 g/m² , RADF - 50 sheets size: A5 (148 x 210 mm) - A4 (210 x 297 mm) weight: 60 g/m² - 105 g/m²
Speed Details
Copying: up to 33 ppm - B/W , Printing: up to 33 ppm - B/W , Scanning: 2 sec - B/W , Scanning: 6 sec - colour
1 x USB 2.0 - 4 pin USB Type B , 1 x USB host - 4 pin USB Type A , 1 x Gigabit LAN - RJ-45
Security Protocols & Features
SSL, TLS, IPsec, 802.1x, IP filtering, MAC address filtering
Operating System Support
Apple Mac OS X 10.7, MS Windows Server 2008 R2 x64 Edition, Apple Mac OS X 10.8, Windows 8, Windows 8 64-bit, Apple Mac OS X 10.6.8, Windows 8.1, Apple Mac OS X 10.9, Windows 8.1 64-bit, MS Windows Server 2012 R2, MS Windows Server 2003 (32/64-bits), MS Windows Server 2008 (32/64-bits), MS Windows Server 2012 R2 x64 Edition, MS Windows Vista (32/64 bits), MS Windows 7 (32/64 bits)
Software Included
OKI Template Manager, OKI LPR, OKI Storage Device Manager, Nuance PaperPort 14, Nuance OmniPage SE 18
AC 230 V (50/60Hz)
600 Watt
Power Consumption Standby
95 Watt
Power Consumption Sleep
1.9 Watt
First Copy Out Time B/W
10 sec
Limited warranty - 3 years
45.5 cm
42.7 cm
42.5 cm
20 kg
Sound Emission
30 dBA (idle) / 53 dBA (operating)
10 °C
32 °C
20 - 80%
Functionality: Scanner
Functionality: Copier
Functionality: Fax
Technology: Laser
Max Print Speed: 33ppm
Max Paper Size: 210 x 1321 mm
Brand: OKI
