The Microline 5590 has been designed for use in the harshest of operating environments whilst offering the highest levels of flexibility and performance with unparalleled reliability.
The ML5590 carriage model features advanced specifications that ensure excellent productivity and reliability every time. Its robustness and flexibility make it the ideal choice for demanding environments. The 24-pin print head also provides a better print quality than 9-pin counter-parts for the printing of invoices, spreadsheets etc.
Forms tear-off
The forms tear-off feature allows a printed continuous forms page to be torn off without wasting paper or adjusting the printer. When printing stops, forms tear-off automatically moves the paper to align the perforation with the tear bar, after a time interval which you select through the menu. Paper remains in the tear-off position until the printer receives more data. Then, the paper moves back down for printing. This feature has to be enabled. -
Paper park
Your printer's paper park feature allows you to print a single sheet (cut-sheet) page without removing continuous feed paper from the printer. -
Top of Form (TOF)
Top of Form (TOF) sets the print start position. The factory default is 1" from the top. The TOF can be changed in increments of 1/144", for a single print job or set to a new default. The overall amount of adjustment is limited to avoid paper jams.
- OKI Microline 5590eco - printer - B/W - dot-matrix
- Printer Type
- Workgroup printer - dot-matrix - 24 pin - B/W
- 5.9 kg
- Max Media Size
- Continuous paper 76 mm - 254 mm (width)
- Min Media Size (Custom)
- 76.2 mm
- Max Media Size (Custom)
- 254 mm
- Print Speed
- Up to 473 char/sec - max speed , Up to 420 char/sec - high speed draft , Up to 378 char/sec - utility , Up to 315 char/sec - utility , Up to 105 char/sec - letter , Up to 126 char/sec - letter
- Max Resolution (B&W)
- 360 dpi
- Interface
- Parallel, USB
- RAM Installed (Max)
- 128 KB
- Language Simulation
- EPSON ESC/P 2, IBM AGM, EPSON LQ, IBM ProPrinter
- Barcodes
- Code 39, EAN/JAN-8, EAN/JAN-13, UPC-A, UPC-E, Interleaved 2 of 5, Postnet, OCR-A, OCR-B, Code 128B, Code 128C, Code 128A
- Media Type
- Envelopes, labels, plain paper, continuous forms
- System Requirements
- Microsoft Windows 2000, Microsoft Windows Vista (32/64 bits), Microsoft Windows XP (32/64 bits), Microsoft Windows Server 2008 (32/64-bits), Microsoft Windows Server 2003 (32/64-bits)
- 3-year warranty with product registration
- 39.8 cm x 34.5 cm x 12 cm
- Printer Type
- Workgroup printer - dot-matrix - 24 pin - monochrome
Printer
- Print Speed
- Up to 473 char/sec - max speed - 15 cpi , Up to 420 char/sec - high speed draft - 10 cpi , Up to 378 char/sec - utility - 12 cpi , Up to 315 char/sec - utility - 10 cpi , Up to 105 char/sec - letter - 10 cpi , Up to 126 char/sec - letter - 12 cpi
- Connectivity Technology
- Wired
- Interface
- Parallel, USB
- 360 dpi
- Fonts Included
- 1 x scalable , 1 x barcode
- Barcodes
RAM
- 128 KB
Media Handling
- Media Path Type
- Curved
- Media Type
- Max Media Size
- 76.2 mm
- 254 mm
- Media Sizes
- Envelope Sizes
- US No 6 (92 x 165 mm)
- Media Feeders
- 1 x manual - 1 sheet - continuous paper 76 mm - 254 mm (width)
- Max Sheets in Multi-Part Form
- 5
- Connections
- 1 x parallel - 36 PIN Centronics , 1 x USB - 4 pin USB Type B
- Consumables Included
- 1 x printhead - up to 200 million characters , 1 x ribbon - up to 4 million characters
- MTBF
- 20,000 hour(s)
- Power Device
- Power supply - internal
- Frequency Required
- 50/60 Hz
- 45.9 Watt
- Power Consumption Stand by / Sleep
- 1.5 Watt
- OS Required
Environmental Standards
- ENERGY STAR
- Limited warranty - 3 years
- Sound Emission (Operating)
- 56 dBA
- Sound Emission (Quiet Mode)
- 52 dBA
- 39.8 cm
- 34.5 cm
- 12 cm
- 5.9 kg
