The ML5520eco printer is suited to high speed, high volume data and word processing applications where fast throughput and flexible paper management are required.
This 9-pin, narrow carriage, impact printer is engineered to be tough enough for dedicated printing in the most demanding environments. With outstanding reliability, ease-of-use and barcoding facilities and the ability to run twice as long as most printers in their class, they are ideal for supporting forms printing at customer service points in wholesale and service environments.
- OKI Microline 5520eco - printer - B/W - dot-matrix
- Printer Type
- Workgroup printer - dot-matrix - 9 pin - B/W
- 5.9 kg
- Max Media Size
- Continuous paper 76 mm - 254 mm (width)
- Min Media Size (Custom)
- 76 mm
- Max Media Size (Custom)
- 254 mm
- Print Speed
- Up to 570 char/sec - super speed draft , Up to 507 char/sec - high speed draft , Up to 380 char/sec - utility , Up to 95 char/sec - near letter
- Max Resolution (B&W)
- 240 x 216 dpi
- Interface
- Parallel, USB
- RAM Installed (Max)
- 128 KB
- Language Simulation
- EPSON FX, Okidata Microline, IBM ProPrinter
- Barcodes
- OCR-B
- Media Type
- Envelopes, plain paper, continuous forms
- 3-year warranty with product registration
- 39.8 cm x 34.5 cm x 12 cm
- Printer Type
- Workgroup printer - dot-matrix - 9 pin - monochrome
Printer
- Print Speed
- Up to 570 char/sec - super speed draft - 12 cpi , Up to 507 char/sec - high speed draft - 10 cpi , Up to 380 char/sec - utility , Up to 95 char/sec - near letter
- Connectivity Technology
- Wired
- Interface
- Parallel, USB
- 240 x 216 dpi
- Fonts Included
- 1 x scalable , 1 x barcode
- Barcodes
- OCR-B
RAM
- 128 KB
Media Handling
- Media Type
- Max Media Size
- 76 mm
- 254 mm
- Media Sizes
- Envelope Sizes
- US No 6 (92 x 165 mm)
- Media Feeders
- 1 x manual - 1 sheet - continuous paper 76 mm - 254 mm (width)
- Max Sheets in Multi-Part Form
- 6
- Connections
- 1 x parallel - 36 PIN Centronics , 1 x USB - 4 pin USB Type B
- Consumables Included
- 1 x printhead - up to 200 million characters , 1 x ribbon - up to 4 million characters
- MTBF
- 20,000 hour(s)
- Power Device
- Power supply - internal
- Frequency Required
- 50/60 Hz
- 40.2 Watt
- Power Consumption Stand by / Sleep
- 1.5 Watt
Environmental Standards
- ENERGY STAR
- Limited warranty - 3 years
- Sound Emission (Operating)
- 56 dBA
- Sound Emission (Quiet Mode)
- 52 dBA
- 39.8 cm
- 34.5 cm
- 12 cm
- 5.9 kg
