Legendary reliability, high-volume output, flexible forms handling, and lightning-fast throughput. This 24-pin dot matrix printer delivers high productivity and superior print quality.
- OKI Microline 395C - printer - colour - dot-matrix
- Printer Type
- Personal printer - dot-matrix - 24 pin - colour
- Form Factor
- Desktop
- 12.3 kg
- Max Media Size (Custom)
- 406 mm
- Print Speed
- Up to 610 char/sec - max speed , Up to 485 char/sec - draft , Up to 245 char/sec - near letter , Up to 165 char/sec - letter
- Max Resolution (B&W)
- 360 dpi
- Interface
- Parallel, serial
- RAM Installed (Max)
- 64 KB
- Language Simulation
- IBM XL24E, EPSON LQ
- Media Type
- Envelopes, plain paper, continuous forms, business cards
- Total Media Capacity
- 1 roll
- Power
- AC 120/230 V
- System Requirements
- Microsoft Windows 3.x/95/98
- Enclosure Colour
- White
- 3 years warranty
- 56.9 cm x 41.7 cm x 18 cm
- Printer Type
- Form Factor
- Desktop
- Enclosure Colour
- White
Printer
- Print Speed
- Connectivity Technology
- Wired
- Interface
- Parallel, serial
- 360 dpi
- PostScript Support
- Not available
RAM
- 64 KB
Media Handling
- Media Path Type
- Curved
- Media Type
- 406 mm
- 1 roll
- Media Feeders
- 1 x manual - 1 roll - Roll (40.6 cm)
Duty Cycle
- Cartridge / Printhead Duty Cycle
- 200 million characters
- Connections
- 1 x parallel - 36 PIN Centronics , 1 x RS-232
- Mounting Kit
- Not available
- Plug and Play
- Power Device
- Power supply - integrated
- Voltage Required
- AC 120/230 V ± 10%
- Frequency Required
- 50/60 Hz
- EPA Energy Star
- Software Included
- Drivers & Utilities
- OS Required
- Limited warranty - 3 years
- Sound Emission
- 58 dBA
- 56.9 cm
- 41.7 cm
- 18 cm
- 12.3 kg
