OKI Microline 395B Mono Dot-Matrix Printer
Quicklinx: 57LWS00 Mfr#: 09000327
The fastest and highest quality printer in OKI's 24-pin dot-matrix range, especially recommended for high volume data processing requirements and quality high volume word processing tasks. The ML395 is excellent for reports and presentations.
  • Enhanced connectivity
    Equipped with both parallel and serial interfaces, this printer offers versatile connectivity options, making it easy to integrate into any PC setup.
  • High-speed printing
    Achieve productivity with a printing speed of up to 607 char/sec, ensuring quick and efficient document handling for all your printing needs.
  • Versatile media handling
    Supports a wide range of media types including continuous forms, envelopes, and plain paper, catering to diverse printing requirements.
  • Crisp monochrome output
    With a resolution of 360 DPI, the OKI Microline 395B delivers clear and sharp monochrome prints, suitable for a variety of documents.
  • Durable design
    Featuring a robust dot-matrix printing technology and a 24 pin printhead, this printer is designed for long-lasting performance and reliability.
OKI Microline 395B - printer - B/W - dot-matrix
Printer Type
Personal printer - dot-matrix - 24 pin - B/W
Desktop
17 kg
Max Media Size (Custom)
406 mm
Print Speed
Up to 607 char/sec - max speed , Up to 162 char/sec - letter , Up to 486 char/sec - draft
Max Resolution (B&W)
360 dpi
Parallel, serial
RAM Installed (Max)
23 KB (40 KB) integrated
Language Simulation
IBM X24E, IBM PPR, EPSON LQ
Media Type
Envelopes, plain paper, continuous forms, business cards
Enclosure Colour
White
3-year warranty
57 cm x 41.7 cm x 18 cm
Printer Type
Personal printer - dot-matrix - 24 pin - monochrome
Desktop
Enclosure Colour
White
Printer
Print Speed
Wired
Parallel, serial
360 dpi
PostScript Support
Not available
Language Simulation
Fonts Included
7 x barcode , 6 x bitmapped
RAM
RAM Installed (Max)
23 KB / 40 KB (max)
Technology / Form Factor
Integrated
Media Handling
Media Path Type
Curved, straight
Media Type
406 mm
Media Sizes
A3 (297 x 420 mm)
Media Feeders
3 x manual
Max Sheets in Multi-Part Form
4
Duty Cycle
Cartridge / Printhead Duty Cycle
200 million characters
1 x RS-232 - 9 pin D-Sub (DB-9) , 1 x parallel - 36 PIN Centronics
Power supply - integrated
Software Included
Drivers & Utilities
Limited warranty - 3 years
57 cm
41.7 cm
18 cm
17 kg
