Multifunction printing at its best
Efficient and cost effective without loss of printing quality or functionality, the OKI MC573dn A4 colour LED laser printer is a natural choice for small to mid-sized business workgroups. It also comes with a full range of features: choose to print, scan, copy and fax at a speed of up to 30 pages per minute in black and white. It's also speedy to get started, turning out the first page in an average of just seven and a half seconds.
Wired or wireless printing - a flexible solution
As well as being multifunctional, this printer is also well connected - you can print from USB, from a traditional workgroup network, as well as wirelessly over WiFi (via the optional wireless device), offering true versatility. Efficiently handling double-sided as well as single-sided printing, it can print at a high definition 1,200 x 1,200 dots per inch, which produces wonderfully crisp and sharp images. Using the latest LED laser-printing technology, you can expect print jobs with professional clarity and depth of tone created by layered, quality inks.
High-capacity and high-yield quality toner inks
A 250-sheet input tray means you won't be waiting around to feed the printer, while high-yield and high-capacity replacement toner cartridges from OKI mean you'll be spending less on overheads. Compatible with both Windows PCs and Macs, it's the perfect accompaniment to a multifunctional office environment. When you choose to buy from a reputable supplier like us, you'll also benefit from our full range of authentic OKI replacement toner cartridges and consumables to complement your printer's many capabilities.
