OKI MC332DN Colour Multifunction Printer
Quicklinx: 9JYRWS00 Mfr#: 01331301
The MC332dn is the perfect print, scan and copy device for a micro business or home office with a low usage and print volume requirement. Color print speeds of 20 ppm and mono print speeds of 22 ppm provide the user with the flexibility to print their marketing materials in-house.
OKI MC332dn - multifunction printer - colour
Multifunction printer
Printing Technology
LED (colour)
Monthly Duty Cycle (max)
30000 pages
Recommended Monthly Volume
2000 pages
Max Copying Speed
Up to 22 ppm (mono) / up to 20 ppm (colour)
Max Copying Resolution
Up to 600 x 600 dpi (mono) / up to 600 x 600 dpi (colour)
Max Printing Speed
Max Printing Resolution
Up to 1200 x 600 dpi (mono) / up to 1200 x 600 dpi (colour)
Scanning
1200 x 1200 dpi
Display
3.5"
Original Size
A4 (210 x 297 mm) (max)
Original Type
Sheets
Document Feeder Capacity
50 sheets
Media Size
210 x 1320 mm (max)
Media Type
Envelopes, plain paper, cards, photo paper, banner
Standard Media Capacity
350 sheets
Max Media Capacity
350 sheets
Bypass Feeder Capacity
100 sheets
Output Trays Capacity
150 sheets
Automatic Duplexing
Yes (copying) Yes (printing) Yes (scanning)
Connection Availability
USB 2.0, LAN, USB host
Office Machine Features
Save to USB flash drive, scan to e-mail, scan to network
AC 230 V (50/60Hz)
42.7 cm x 50.9 cm x 44.4 cm
29 kg
Microsoft Certification
Compatible with Windows 7
Environmental Standards
ENERGY STAR Qualified
3-year warranty with product registration
Printing Technology
LED - colour
30000 pages
2000 pages
Display Diagonal Size
3.5"
Standard Memory
256 MB
Max Supported Memory
768 MB
Copying
Max Copying Speed
Max Document Enlargement
400%
Max Document Reduction
25%
Maximum Copies
99
Automatic Duplexing
Copying Features
ID Card Copy, collation copy
Printing
Max Printing Speed
Printer Drivers / Emulations
PCL 6, PostScript 3, PCL 5c, IBM Proprinter
Image Enhancement Technology
OKI ProQ2400 Multilevel
Automatic Duplexing
First Print Out Time B/W
8.5 sec
First Print Out Time Colour
9 sec
Colour Management Features
ICC Color Profiles
Scanning
Automatic Duplexing
Optical Resolution
1200 x 1200 dpi
Colour Depth
24-bit
Colour Depth (Internal)
48-bit
Document & Media Handling
Max Original Size
A4 (210 x 297 mm)
Original Type
Sheets
50 sheets
Max Media Size
A4
Min Media Weight
64 g/m²
Max Media Weight
220 g/m²
Supported Media Type
Supported Media Sizes
A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), A6 (105 x 148 mm), 100 x 150 mm, 75 x 125 mm, 125 x 175 mm
Supported Envelope Sizes
International DL (110 x 220 mm), International C6 (114 x 162 mm), Com-10 (105 x 241 mm), International C5 (162 x 229 mm), Com-9 (98 x 225 mm)
350 sheets
Max Media Capacity
350 sheets
100 sheets
150 sheets
RADF - 50 sheets - A4 (210 x 297 mm) weight: 60 g/m² - 105 g/m² , Bypass tray - 100 sheets - 210 x 1320 mm weight: 64 g/m² - 220 g/m² , Input tray - 250 sheets - A4 (210 x 297 mm) weight: 64 g/m² - 176 g/m² , Output tray - 150 sheets
Speed Details
Copying: up to 22 ppm - B/W , Copying: up to 20 ppm - colour , Printing: up to 22 ppm (A4) - B/W , Printing: up to 20 ppm (A4) - colour , Scanning: up to 20 ppm - colour , Scanning: up to 30 ppm - B/W
1 x USB 2.0 - 4 pin USB Type B , 1 x USB host - 4 pin USB Type A , 1 x LAN - RJ-45
Security Protocols & Features
LDAP, SSL, Apple Bonjour, TLS, IPsec, 802.1x, IP filtering, ARP, MAC address filtering
Operating System Support
MS Windows XP, MS Windows Server 2003, MS Windows Server 2008 x64 Edition, MS Windows 7, MS Windows 7 64-bit Edition, MS Windows Vista, MS Windows XP 64-bit Edition, MS Windows Server 2003 x64 Edition, MS Windows Vista (64-bit versions), MS Windows Server 2008, MS Windows Server 2008 R2 x64 Edition, Windows 8, Windows 8 64-bit, Apple Mac OS X 10.3.9 - 10.8
Software Included
OKI PrintSuperVision, OKI Color Swatch Utility, OKI Color Correct Utility, OKI Template Manager, OKI LPR, Nuance PaperPort SE 11, Nuance OmniPage SE 16
AC 230 V (50/60Hz)
500 Watt
Power Consumption Standby
100 Watt
Power Consumption Sleep
1.2 Watt
Warm-Up Time
60 sec
First Copy Out Time B/W
12 sec
First Copy Out Time Colour
14 sec
Consumables Included
1 x toner cartridge (black) - up to 750 pages , 1 x toner cartridge (cyan) - up to 750 pages , 1 x toner cartridge (magenta) - up to 750 pages , 1 x toner cartridge (yellow) - up to 750 pages
Supported Windows 7 Features
Windows HD Imaging
ENERGY STAR Certified
Limited warranty - 3 years
42.7 cm
50.9 cm
44.4 cm
29 kg
Sound Emission
33 dBA (idle) / 52 dBA (operating)
10 °C
32 °C
20 - 80%
