OKI MB770dn Mono Laser Multifunction Printer
Quicklinx: 9G2RWS00 Mfr#: 01334402
The OKI MB770 mono MFP series combines high-quality output and four-in-one functionality with speed, reliability and ease of use - superior value from MFP that has a footprint small enough to fit easily into your environment. The MB770 has a robust super G3 fax with dual access, T.37 Internet faxing, a 3,000-entry address book, double-sided fax scanning, and the ability to let you send faxes directly from your PC. It can make your job easier - the MB770 MFP series is user friendly: network-ready right out of the box, with an intuitive operator panel that's simple to use: a 9" color touch-screen graphic display, an alphanumeric keypad and function buttons.
  • Enhance the productivity of your staff
    The MB770's duplexing/reversing automatic document feeder (RADF) quickly scans both sides of a document. And, with its robust duty cycles, this durable device can be relied upon to handle large daily print and copy volumes. Scan at the machine or from your desk - turn hard-copy documents into electronic files with multiple options. Scan color or black and white documents in, and send them to your PC, a network folder, a USB stick, or to a list of e-mail addresses.
  • The convenience of E-filing
    Store your digital documents on or transfer them from "boxes" on the MFP's secure hard disk drive. Users have walk-up-and-print or pull-down (to their PCs) access to all documents in the public box, or access via password to documents in private boxes. Passwords can be assigned to specific users or shared within a department.
  • Full-featured fax
  • Improve your bottom line
    The MB770 MFP series delivers cost-effective operation as well as an exceptional return on your investment. Its outstanding reliability and long-lasting consumables help you control operating costs and improve productivity.
OKI MB770dn - multifunction printer - B/W
Multifunction printer
Printing Technology
LED (monochrome)
Monthly Duty Cycle (max)
200000 pages
Recommended Monthly Volume
30000 pages
Max Copying Speed
Up to 52 ppm
Max Copying Resolution
Up to 600 dpi
Max Printing Speed
Up to 52 ppm
Max Printing Resolution
Up to 1200 x 1200 dpi
Scanning
600 x 600 dpi
Original Size
A4 (210 x 297 mm) (max)
Original Type
Sheets
Document Feeder Capacity
100 sheets
Media Size
64 x 127 mm (min) - 216 x 1321 mm (max)
Media Type
Envelopes, plain paper, labels
Standard Media Capacity
630 sheets
Max Media Capacity
3160 sheets
Bypass Feeder Capacity
100 sheets
Stapler
Included
Automatic Duplexing
Yes (copying) Yes (printing) Yes (scanning)
Connection Availability
USB 2.0, Gigabit LAN, USB host
Office Machine Features
Save to USB flash drive, scan to e-mail, sXP (smart Extendable Platform)
AC 230 V (50/60Hz)
52.2 cm x 56.4 cm x 67.5 cm
50 kg
Environmental Standards
ENERGY STAR Qualified
3-year warranty with product registration
Printing Technology
LED - monochrome
200000 pages
30000 pages
Display Features
Touch screen
Standard Memory
2 GB
Hard Disk Drive
160 GB
Copying
Max Copying Speed
Up to 52 ppm
Up to 600 dpi
Max Document Enlargement
400%
Max Document Reduction
25%
Maximum Copies
999
Automatic Duplexing
Copying Features
ID Card Copy, Job Build
Printing
Max Printing Speed
Up to 52 ppm
Printer Drivers / Emulations
PCL 5e, PCL 6, PostScript 3, PCL 5c, PDF, XPS
Automatic Duplexing
First Print Out Time B/W
5 sec
Scanning
Automatic Duplexing
Optical Resolution
600 x 600 dpi
Colour Depth
24-bit
Document & Media Handling
Max Original Size
A4 (210 x 297 mm)
Original Type
Sheets
100 sheets
Min Media Size
64 x 127 mm
Max Media Size
A4
Min Media Weight
64 g/m²
Max Media Weight
250 g/m²
Supported Media Type
Supported Media Sizes
A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), A6 (105 x 148 mm)
Supported Envelope Sizes
International DL (110 x 220 mm), Com-10 (105 x 241 mm), International C5 (162 x 229 mm), Com-9 (98 x 225 mm)
630 sheets
Max Media Capacity
3160 sheets
100 sheets
Bypass tray - 100 sheets size: 64 x 127 mm - 216 x 1321 mm weight: 64 g/m² - 250 g/m² , Input tray - 530 sheets - A4 (210 x 297 mm) weight: 64 g/m² - 220 g/m² , ADF - 100 sheets - A4 (210 x 297 mm) weight: 60 g/m² - 105 g/m² , Stapler - 20 sheets
Speed Details
Copying: up to 52 ppm - B/W , Printing: up to 52 ppm (A4) - B/W , Scanning: up to 40 ipm - colour , Scanning: up to 55 ipm - B/W
Finishing Equipment
Stapler
Included
1 x USB 2.0 - 4 pin USB Type B , 1 x USB host - 4 pin USB Type A , 1 x Gigabit LAN - RJ-45
Security Protocols & Features
LDAP, Secure Print, SSL, Apple Bonjour, TLS, IP filtering, ARP, MAC address filtering
Operating System Support
UNIX, Linux, MS Windows XP SP2 or later, Apple Mac OS X 10.4, Apple Mac OS X 10.5, MS Windows 7, MS Windows Vista SP1, MS Windows 7 64-bit Edition, MS Windows Vista SP2, Apple Mac OS X 10.6, Apple Mac OS X 10.7, MS Windows Vista SP2 64-bit Edition, MS Windows Server 2008 R2 x64 Edition, Apple Mac OS X 10.8, Windows 8, MS Windows Server 2008 SP1, MS Windows Server 2003 SP2, Windows 8 64-bit, MS Windows Server 2012 x64 Edition
Software Included
OKI PrintSuperVision, OKI Template Manager
AC 230 V (50/60Hz)
870 Watt
Power Consumption Standby
120 Watt
Power Consumption Sleep
2 Watt
Warm-Up Time
35 sec
First Copy Out Time B/W
8 sec
Consumables Included
1 x toner cartridge (black) - up to 10000 pages
GS
ENERGY STAR Certified
Limited warranty - 3 years
52.2 cm
56.4 cm
67.5 cm
50 kg
Sound Emission
30 dBA (idle) / 58 dBA (operating)
10 °C
32 °C
20 - 80%
9G2R OKI High Capacity Black Print Cartridge 36k Yield In Stock £297.54
9G2R OKI Standard Capacity Print Cartridge 18K In Stock £255.60
