The C841 is suited to creative organizations or departments that require photographic quality output at 1200 x 1200 dpi. With fast print speeds, high capacity toners and low running cost this is the perfect A3/A4 color printer to support your own business as well as your customers. The C841 provides complete flexibility, enabling users to print on a wide range of media sizes, formats and paper weights.
Excellent color made easy
You don't need any special skills or training to get the best out of your C841. It has 1200 x 1200 dpi print resolution for smoother shades, there's a photo enhance setting for printing sharp, photo-like pictures, and support for support for PCL and PostScript for when you're working with graphics files and applications. -
Rapid print speeds
Not only can the C841 can print all your routine A4 documents at speeds of up to 35 pages per minute (ppm). Even in A3, it still prints at a highly capable 20 ppm. And that's not all. Because it comes with 256 MB RAM, expandable to 768MB, and a powerful 800 MHz processor as standard, you can work with large and complex documents as easily as small and simple ones. -
Versatile media handling
Your team can do so much more with the C841. Documents can be any size from A6 postcards, right the way up to A3 and beyond to 1321 mm banners. It handles paper weights from as light as 64 to as heavy as 256 gsm, and it has a standard 400-sheet paper capacity that can be expanded 1,990 sheets for more printing with fewer interruptions. -
Support your environmental objectives
The C841dn comes with automatic two-sided printing as standard, helping people to reduce paper usage and saves money. A useful deep sleep function helps to reduce energy consumption, and toner cartridges which last for around 10,000 pages each mean less waste and packaging.
- OKI C841dn - printer - colour - LED
- Printer Type
- Workgroup printer - LED - colour
- 40 kg
- Media Size Class
- A3
- Max Media Size
- A3 (297 x 420 mm)
- Max Media Size (Custom)
- 297 mm x 1321 mm
- Print Speed
- Up to 35 ppm - B/W - A4 (210 x 297 mm) , Up to 35 ppm - colour - A4 (210 x 297 mm) , Up to 20 ppm - B/W - A3 (297 x 420 mm) , Up to 20 ppm - colour - A3 (297 x 420 mm)
- Max Resolution (B&W)
- 1200 dpi
- Max Resolution (Colour)
- 1200 dpi
- Automatic Duplexing
- Interface
- USB, LAN
- Processor
- 800 MHz
- RAM Installed (Max)
- 256 MB (768 MB)
- Language Simulation
- PCL 5C, PostScript 3, EPSON FX, IBM PPR, PCL 6, PDF 1.8
- Barcodes
- OCR-A, OCR-B, ZIP
- Media Type
- Envelopes, plain paper, banner paper
- Total Media Capacity
- 400 sheets
- Media Handling
- 100-sheet multipurpose tray, 300-sheet input tray
- Monthly Duty Cycle (max)
- 75000 pages
- Recommended Monthly Volume
- 1500 - 5000 pages
- Networking
- Print server - Ethernet, Fast Ethernet - internal
- System Requirements
- Microsoft Windows 2000, Microsoft Windows XP Home Edition, Microsoft Windows XP Professional, Microsoft Windows Server 2003, Microsoft Windows 7, Microsoft Windows XP Professional x64 Edition, Microsoft Windows Vista, Microsoft Windows 7 64-bit Edition, Microsoft Windows Server 2003 x64 Edition, Microsoft Windows Vista (64-bit versions), Microsoft Windows Server 2008, Microsoft Windows Server 2008 x64 Edition, Microsoft Windows Server 2008 R2 x64 Edition, Apple MacOS X 10.3.9 - 10.7
- Microsoft Certification
- Compatible with Windows 7
- 3-year warranty with product registration
- 44.9 cm x 55.2 cm x 36 cm
- Printer Type
Printer
- Print Speed
- Built-in Devices
- Status LCD
- Connectivity Technology
- Wired
- Interface
- USB, LAN
- 1200 dpi
- 1200 dpi
- PostScript Support
- Standard
- First Print Out Time B/W
- 9.5 sec
- First Print Out Time Colour
- 9.5 sec
- Fonts Included
- 87 x scalable PCL , 80 x scalable PostScript , 1 x bitmapped PCL , 1 x barcode
- Barcodes
- OCR-A, OCR-B, ZIP
- Media Handling
- Processor
- 800 MHz
RAM
- 256 MB / 768 MB (max)
Media Handling
- Media Type
- Media Size Class
- A3
- Max Media Size
- A3 (297 x 420 mm)
- 297 mm x 1321 mm
- Media Sizes
- A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), A3 (297 x 420 mm), B4 (250 x 353 mm), A6 (105 x 148 mm)
- Envelope Sizes
- International DL (110 x 220 mm), Com-10 (105 x 241 mm), International C5 (162 x 229 mm), Monarch (98.4 x 190.5 mm), International C4 (229 x 324 mm)
- Media Weight
- 64 g/m² - 256 g/m²
- 400 sheets
- Media Feeders
- 1 x automatic - 100 sheets weight: 64 g/m² - 256 g/m² , 1 x automatic - 300 sheets - A3 (297 x 420 mm) weight: 64 g/m² - 220 g/m²
- Max Media Capacity
- 1990 sheets
- Output Trays Capacity
- 250 sheets
Duty Cycle
- 75000 pages
- 1500 - 5000 pages
- Networking
- Print server - internal
- Data Link Protocol
- Remote Management Protocol
- SNMP 3, HTTPS
- Secure Print, SSL, TLS, 802.1x, IP filtering, MAC address filtering
- Expansion Slots
- Memory
- Connections
- 1 x LAN - RJ-45 , 1 x USB 2.0 - 4 pin USB Type B
- Consumables Included
- 1 x toner cartridge (black) - up to 2500 pages ISO/IEC 19798 , 1 x toner cartridge (cyan) - up to 2500 pages ISO/IEC 19798 , 1 x toner cartridge (magenta) - up to 2500 pages ISO/IEC 19798 , 1 x toner cartridge (yellow) - up to 2500 pages ISO/IEC 19798
- Supported Windows 7 Features
- Windows HD Imaging
- Power Device
- Power supply - internal
- Frequency Required
- 50/60 Hz
- 700 Watt
- Power Consumption Stand by / Sleep
- 100 Watt
- Software Included
- OKI LPR, OKI PrintSuperVision.net, OKI Web Driver Installer, OKI Web Print, OKI Profile Assistant, OKI Storage Device Manager, OKI Color Correct, OKI Color Swatch Utility, OKI Template Manager, OKI PDF Direct Utility, OKI PS Gamma Adjuster, OKI Color Access Policy Manager
- OS Required
Environmental Standards
- ENERGY STAR
- Limited warranty - 3 years
- 10 °C
- 32 °C
- 20 - 80%
- Sound Emission (Idle)
- 32 dBA
- Sound Emission (Operating)
- 52 dBA
- 44.9 cm
- 55.2 cm
- 36 cm
- 40 kg
