OKI C822n A3 Colour Laser Printer
Quicklinx: 866MWS00 Mfr#: 01328601
The C822 is the perfect A3/A4 color printer for a micro or small businesses or workgroups. You will benefit from extensive media flexibility from A6 to A3 and high quality output so you can print your day-to-day business documents from one compact device. And with a low initial capital outlay, the C822 makes in-house color printing more accessible even when budgets are tight.
  • Fast, robust and superb color print quality
    The C822 is built on tried and tested LED technology that your business can rely on to deliver over and over again.
  • Excellent media flexibility to support your business
    The C822 provides complete flexibility, enabling users to print on a wide range of media sizes, formats and paper weights.
OKI C822n - printer - colour - LED
Printer Type
Workgroup printer - LED - colour
37 kg
Media Size Class
A3
Max Media Size
A3 (297 x 420 mm)
Min Media Size (Custom)
148.5 mm x 182 mm
Max Media Size (Custom)
297 mm x 1321 mm
Print Speed
Up to 23 ppm - B/W - A4 (210 x 297 mm) , Up to 23 ppm - colour - A4 (210 x 297 mm) , Up to 13 ppm - B/W - A3 (297 x 420 mm) , Up to 13 ppm - colour - A3 (297 x 420 mm)
Max Resolution (B&W)
1200 x 600 dpi
Max Resolution (Colour)
1200 x 600 dpi
Image Enhancement Technology
OKI ProQ2400 Multilevel
USB, LAN
800 MHz
RAM Installed (Max)
256 MB (768 MB)
Language Simulation
PCL 5C, EPSON FX, IBM PPR, PCL 6
Barcodes
OCR-A, OCR-B, ZIP
Media Type
Envelopes, plain paper
Total Media Capacity
400 sheets
Media Handling
100-sheet multipurpose tray, 300-sheet input tray
Monthly Duty Cycle (max)
75000 pages
Recommended Monthly Volume
5000 pages
Print server - Ethernet, Fast Ethernet
Printer Features
Optional duplex
Microsoft Windows 2000, Microsoft Windows XP Home Edition, Microsoft Windows XP Professional, Microsoft Windows Server 2003, Microsoft Windows 7, Microsoft Windows XP Professional x64 Edition, Microsoft Windows Vista, Microsoft Windows 7 64-bit Edition, Microsoft Windows Server 2003 x64 Edition, Microsoft Windows Vista (64-bit versions), Microsoft Windows Server 2008, Microsoft Windows Server 2008 x64 Edition, Microsoft Windows Server 2008 R2 x64 Edition, Apple MacOS X 10.3.9 - 10.7
Microsoft Certification
Compatible with Windows 7
3-year warranty with product registration
44.9 cm x 55.2 cm x 36 cm
Printer Type
Printer
Print Speed
Built-in Devices
Status LCD
Wired
USB, LAN
1200 x 600 dpi
1200 x 600 dpi
First Print Out Time B/W
14 sec
First Print Out Time Colour
14 sec
Language Simulation
Fonts Included
87 x scalable PCL , 1 x bitmapped PCL , 1 x barcode
Barcodes
OCR-A, OCR-B, ZIP
Printer Features
Optional duplex
Media Handling
800 MHz
RAM
RAM Installed (Max)
256 MB / 768 MB (max)
Media Handling
Media Type
Media Size Class
A3
Max Media Size
A3 (297 x 420 mm)
148.5 mm x 182 mm
297 mm x 1321 mm
Media Sizes
A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), A3 (297 x 420 mm), B4 (250 x 353 mm), A6 (105 x 148 mm)
Envelope Sizes
International DL (110 x 220 mm), Com-10 (105 x 241 mm), International C5 (162 x 229 mm), Monarch (98.4 x 190.5 mm), International C4 (229 x 324 mm)
Media Weight
64 g/m² - 256 g/m²
400 sheets
Media Feeders
1 x automatic - 300 sheets - A3 (297 x 420 mm) weight: 64 g/m² - 220 g/m² , 1 x automatic - 100 sheets weight: 64 g/m² - 256 g/m²
Max Media Capacity
930 sheets
Output Trays Capacity
250 sheets
Duty Cycle
75000 pages
5000 pages
Print server
Remote Management Protocol
SNMP 3, HTTPS
Security Protocols & Features
Secure Print, SSL, TLS, 802.1x, IP filtering, MAC address filtering
Expansion Slots
1 x USB 2.0 - 4 pin USB Type B , 1 x LAN - RJ-45
Consumables Included
1 x toner cartridge (black) - up to 2500 pages ISO/IEC 19798 , 1 x toner cartridge (cyan) - up to 2500 pages ISO/IEC 19798 , 1 x toner cartridge (magenta) - up to 2500 pages ISO/IEC 19798 , 1 x toner cartridge (yellow) - up to 2500 pages ISO/IEC 19798
Power supply - internal
Frequency Required
50/60 Hz
700 Watt
Power Consumption Stand by / Sleep
12 Watt
Software Included
OKI LPR, OKI PrintSuperVision.net, OKI Web Driver Installer, OKI Web Print, OKI Profile Assistant, OKI Storage Device Manager, OKI Color Swatch Utility, OKI Template Manager, OKI Color Access Policy Manager
Environmental Standards
ENERGY STAR
Limited warranty - 3 years
10 °C
32 °C
20 - 80%
Sound Emission (Idle)
32 dBA
Sound Emission (Operating)
52 dBA
44.9 cm
55.2 cm
36 cm
37 kg
866M OKI C822 Yellow Toner 7K In Stock £200.90
866M OKI C822 MagentaToner 7K In Stock £200.90
866M OKI C822 CyanToner 7K In Stock £200.90
866M OKI C822 BlackToner 7K In Stock £84.51
866M OKI C822/831/841 MAGENTA Image Drum 30K In Stock £141.48
866M OKI C822/831/841 Cyan Image Drum 30K In Stock £141.48
866M OKI C822/831/841 Black Image Drum 30K In Stock £141.48
866M OKI C822/831/841 Yellow Image Drum 30K In Stock £141.48
866M OKI C822 Fuser Unit In Stock £97.92
