If you need a color printer that's fast and robust enough to take care of the needs of your entire team - even at the busiest times - look no further than the C610. Rapid print speeds, class leading media handling, and low energy consumption all combine to make this printer the ideal solution to effortlessly support business workgroups of up to 10 users.
The C610's ability to print on paper stocks of up to 250gsm coupled with Oki's High Definition Color technology means your business can produce color vibrant professional documents in-house with ease. Allowing you to print what you want, when you want it, avoiding unnecessary wastage costs and delays.
The C610 delivers maximum performance at exceptional value for money. Taking care to keep costs to a minimum the C610 has an attractive price tag, high yield toners and a long life image drum. In addition, included ‘in the box' are 3 utilities - print control, color access policy manager and PrintSuperVision. With features allowing you to track, monitor and control print usage and costs.
With integrated network capabilities as standard, the C610n is ideal for meeting the everyday demands of workgroups.
Tackle the toughest deadlines
Thanks to the exceptional 'first page to print' time of just 9 seconds and fast print speeds of up to 36 pages per minute, there's no waiting around for documents to print, helping your team to meet and beat the toughest deadlines. -
Print on the paper you want
The C610's ability to print on paper stocks of up to 250gsm coupled with Oki's High Definition Color technology means your business can produce color vibrant professional documents in-house with ease. Allowing you to print what you want, when you want it, avoiding unnecessary wastage costs and delays. -
Reduce the cost of printing
The C610 delivers maximum performance at exceptional value for money. Taking care to keep costs to a minimum the C610 has an attractive price tag, high yield toners and a long life image drum. In addition, included ‘in the box' are 3 utilities - print control, color access policy manager and PrintSuperVision. With features allowing you to track, monitor and control print usage and costs. -
Environmental efficiencies
At a time when cost savings are paramount, but the pressure to become more environmentally friendly increases, the C610 is a product that can help achieve both, consuming just 1.2 watts in 'sleep' mode. -
Unrivaled media flexibility
Print on heavy weight paper and light card paper up to 250 gsm and any size from A6 to A4 through to a 1.2-meter banner. -
Low cost of ownership
With the best price: performance ratio in its class, the C610 is inexpensive to own. A low cost per page and energy-saving features give it an impressively low total cost of ownership. -
Energy-efficient
Thanks to an advanced processor and efficient design, the C610 consumes less energy than similar printers using as little as 1.2 watts once in 'sleep' mode.
- OKI C610n - printer - colour - LED
- Printer Type
- Workgroup printer - LED - colour
- 26 kg
- Media Size Class
- A4/Legal
- Max Media Size
- Legal (216 x 356 mm), A4 (210 x 297 mm)
- Print Speed
- Up to 36 ppm - B/W - A4 (210 x 297 mm) , Up to 34 ppm - colour - A4 (210 x 297 mm)
- Max Resolution (B&W)
- 1200 x 600 dpi
- Image Enhancement Technology
- OKI ProQ2400 Multilevel
- Interface
- USB, LAN
- Processor
- 533 MHz
- RAM Installed (Max)
- 256 MB (768 MB)
- Flash Memory Installed (Max)
- (16 GB)
- Language Simulation
- PCL 5C, PostScript 3, PCL 6, XPS, SIDM, PDF 1.7
- Barcodes
- UPC-A, UPC-B, ZIP
- Media Type
- Envelopes, labels, plain paper
- Total Media Capacity
- 400 sheets
- Media Handling
- 100-sheet multipurpose tray, 300-sheet input tray
- Monthly Duty Cycle (max)
- 75000 pages
- Recommended Monthly Volume
- 5000 pages
- Networking
- Print server - Ethernet, Fast Ethernet - integrated
- Printer Features
- Optional duplex
- System Requirements
- Microsoft Windows 2000, Microsoft Windows XP Home Edition, Microsoft Windows XP Professional, Microsoft Windows Server 2003, Microsoft Windows 7, Microsoft Windows XP Professional x64 Edition, Apple MacOS X 10.3.9, Apple MacOS X 10.6, Microsoft Windows Vista (32-bit versions), Microsoft Windows Server 2003 x64 Edition, Microsoft Windows Vista (64-bit versions), Microsoft Windows Server 2008, Microsoft Windows Server 2008 x64 Edition
- Microsoft Certification
- Certified for Windows Vista
- 3-year warranty with product registration
- 43.5 cm x 54.6 cm x 34 cm
- Printer Type
Printer
- Print Speed
- Built-in Devices
- Status LCD
- Connectivity Technology
- Wired
- Interface
- USB, LAN
- 1200 x 600 dpi
- PostScript Support
- Standard
- First Print Out Time B/W
- 8 sec
- First Print Out Time Colour
- 9 sec
- Fonts Included
- 136 x PostScript , 87 x PCL
- Barcodes
- UPC-A, UPC-B, ZIP
- Printer Features
- Optional duplex
- Media Handling
- Processor
- 533 MHz
RAM
- 256 MB / 768 MB (max)
Flash Memory
- Flash Memory
- 16 GB (max)
Media Handling
- Media Type
- Media Size Class
- A4/Legal
- Max Media Size
- Media Sizes
- Legal (216 x 356 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), A6 (105 x 148 mm)
- Envelope Sizes
- International DL (110 x 220 mm), Com-10 (105 x 241 mm), International C5 (162 x 229 mm), Monarch (98.4 x 190.5 mm), Com-9 (98 x 225 mm)
- Media Weight
- 64 g/m² - 250 g/m²
- 400 sheets
- Media Feeders
- 1 x automatic - 300 sheets - Legal (216 x 356 mm) weight: 64 g/m² - 220 g/m² , 1 x automatic - 100 sheets - Legal (216 x 356 mm) weight: 64 g/m² - 250 g/m²
- Max Media Capacity
- 1460 sheets
- Output Trays Capacity
- 350 sheets
Duty Cycle
- 75000 pages
- 5000 pages
- Networking
- Print server - integrated
- Data Link Protocol
- TCP/IP, UDP/IP, NetBEUI/NetBIOS, ICMP/IP, LPR/LPD, ARP, SMTP, FTP, BOOTP, DHCP, DNS, POP3, SMB
- Remote Management Protocol
- SNMP 1, Telnet, SNMP 3, HTTP, NDPS, NDS
- Secure Print, SSL, Apple Bonjour, TLS, IPsec, 802.1x
- Expansion Slots
- Memory
- Connections
- 1 x LAN - RJ-45 , 1 x USB 2.0 - 4 pin USB Type B
- Certified for Windows Vista software and devices have undergone compatibility tests for ease-of-use, better performance and enhanced security.
- Supported Windows 7 Features
- Windows HD Imaging
- Power Device
- Power supply - internal
- Frequency Required
- 50/60 Hz
- 600 Watt
- Power Consumption Stand by / Sleep
- 1.2 Watt
- Software Included
- OKI LPR, OKI Print Control Client, OKI Print Control Server, OKI PrintSuperVision.net, OKI Swatch Utility, OKI Web Driver Installer, OKI Gamma Utility, OKI Profile Assistant, OKI Storage Device Manager, OKI Color Correct, OKI Template Manager, OKI Color Access Policy Manager
- OS Required
Environmental Standards
- ENERGY STAR
- Limited warranty - 3 years
- 10 °C
- 32 °C
- 20 - 80%
- Sound Emission (Idle)
- 37 dBA
- Sound Emission (Operating)
- 54 dBA
- 43.5 cm
- 54.6 cm
- 34 cm
- 26 kg
OKI C610 Magenta Toner | In Stock | £180.67 |
OKI C610 Yellow Image Drum | In Stock | £128.09 |
OKI C610 Cyan Image Drum | In Stock | £128.09 |
OKI C610 Fuser Unit | In Stock | £135.43 |
