Transform your black and white documents with the B840, the A3 printer with the speed, versatility and footprint of an A4 device. With sharper mono output, provided by OKI's innovative digital LED technology, the B840 brings A4 and A3 mono printing closer to your work group. Gone are the days of having to decipher your spreadsheets and diagrams with a magnifying glass. The B840 provides the convenience of fast desktop A4 printing speeds of up to 40 ppm with the capability to print your documents at a size that gives them and you a new perspective. The B840 brings affordable A4 and A3 mono printing to every business, large or small.
Fast, superior mono printing on your desktop
The B840 has an impressive print speed of 40 ppm for A4 and 22 ppm for A3. With the combination of large RAM memory, fast processing power and its high print resolution, pin-sharp output is assured quickly every time - a must for all customer facing documents and output. -
Flexible media output and duplex printing
Able to handle a wide range of media from A6 to A3 and paper weights of up to 200 gsm, the B840 is ideal for reducing costs through printing essential business documents in-house. In addition, the B840dn model offers duplex printing, and the standard paper capacity of 630 sheets can be expanded to up to 1,690 sheets for a wider range of output. -
Reduced running costs and lower TCO
The B840 has been designed to provide a cost effective printing resource that can sit on the desktop, closer to the work group. With the energy saving sleep mode your power consumption is reduced, conserving energy, lowering your running costs and carbon footprint. -
Packed full of value-added features
Putting you in control, the software utilities and features provide even more value for your money. Secure Print removes the risk of sensitive information falling into the wrong hands. Whilst PrintSuperVision provides remote monitoring and management of printers across your network and Print Control allows you to control your print costs and usage. -
Combining reliable technology with minimal user intervention
The B840 is built on tried and tested digital LED technology, developed by OKI. The robust design and innovative technology not only deliver outstanding reliability, but also the 100k duty cycle offers you consistently high quality prints over and over again, further reducing user intervention.
- OKI B840dn - printer - B/W - LED
- Printer Type
- Workgroup printer - LED - B/W
- 28 kg
- Media Size Class
- A3
- Max Media Size
- A3 (297 x 420 mm)
- Min Media Size (Custom)
- 76 mm x 148 mm
- Max Media Size (Custom)
- 297 mm x 431.8 mm
- Print Speed
- Up to 40 ppm - max speed - A4 (210 x 297 mm) , Up to 22 ppm - max speed - A3 (297 x 420 mm)
- Max Resolution (B&W)
- 1200 dpi
- Automatic Duplexing
- Interface
- Parallel, USB, LAN
- Processor
- PowerPC 464FP H90 533 MHz
- RAM Installed (Max)
- 128 MB (640 MB)
- Language Simulation
- PCL 5E, PostScript 3, EPSON FX, IBM PPR, SIDM
- Barcodes
- ZIP
- Media Type
- Envelopes, labels, plain paper
- Total Media Capacity
- 630 sheets
- Media Handling
- 100-sheet multipurpose tray, 530-sheet input tray
- Monthly Duty Cycle (max)
- 100000 pages
- Recommended Monthly Volume
- 20000 pages
- Networking
- Print server - Ethernet, Fast Ethernet
- System Requirements
- Microsoft Windows Server 2008 R2, Apple MacOS X 10.3.9 - 10.6, Microsoft Windows 7 (32/64 bits), Microsoft Windows XP (32/64 bits), Microsoft Windows Server 2008 (32/64-bits), Microsoft Windows Server 2003 (32/64-bits)
- Microsoft Certification
- Compatible with Windows 7
- 3-year warranty with product registration
- 48.5 cm x 52.1 cm x 38.3 cm
- Printer Type
- Workgroup printer - LED - monochrome
Printer
- Print Speed
- Built-in Devices
- Status LCD
- Connectivity Technology
- Wired
- Interface
- 1200 dpi
- PostScript Support
- Standard
- First Print Out Time B/W
- 5 sec
- Fonts Included
- 87 x scalable PCL , 3 x bitmapped , 136 x scalable PostScript , 1 x barcode
- Barcodes
- ZIP
- Media Handling
- Processor
RAM
- 128 MB / 640 MB (max)
- Slots Qty
- 1
- Empty Slots
- 1
Media Handling
- Media Type
- Media Size Class
- A3
- Max Media Size
- A3 (297 x 420 mm)
- 76 mm x 148 mm
- 297 mm x 431.8 mm
- Media Sizes
- A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), A3 (297 x 420 mm), B4 (250 x 353 mm), A6 (105 x 148 mm)
- Envelope Sizes
- International DL (110 x 220 mm), Com-10 (105 x 241 mm), International C5 (162 x 229 mm), Monarch (98.4 x 190.5 mm), International C4 (229 x 324 mm), Com-9 (98 x 225 mm)
- Media Weight
- 60 g/m² - 200 g/m²
- 630 sheets
- Media Feeders
- 1 x automatic - 530 sheets - A3 (297 x 420 mm) weight: 60 g/m² - 176 g/m² , 1 x automatic - 100 sheets - 297 x 432 mm weight: 60 g/m² - 200 g/m²
- Max Media Capacity
- 1690 sheets
- Output Trays Capacity
- 250 sheets
Duty Cycle
- 100000 pages
- 20000 pages
- Networking
- Print server
- Data Link Protocol
- TCP/IP, IPX/SPX, AppleTalk, NetBEUI/NetBIOS, ICMP/IP, LPR/LPD, ARP, SMTP, FTP, BOOTP, DHCP, DNS, POP3, RARP, Bonjour
- Remote Management Protocol
- SNMP 1, SNMP 2, Telnet, SNMP 3, HTTP
- Apple Bonjour, TLS, IPsec, 802.1x
- Connections
- 1 x USB 2.0 - 4 pin USB Type B , 1 x parallel - 36 PIN Centronics , 1 x LAN - RJ-45
- Consumables Included
- 1 x toner cartridge (black) - up to 6000 pages ISO/IEC 19752
- Green Tick
- Power Device
- Power supply - internal
- Frequency Required
- 50/60 Hz
- 550 Watt
- Power Consumption Stand by / Sleep
- 75 Watt
- Software Included
- OKI PrintSuperVision, OKI LPR, OKI Print Control Client, OKI Print Control Server, OKI Web Driver Installer, OKI Storage Device Manager, OKI Network Extension, OKI Template Manager, OKI PDF Print Direct
- OS Required
Environmental Standards
- ENERGY STAR
- Limited warranty - 3 years
- 10 °C
- 32 °C
- 20 - 80%
- Sound Emission (Idle)
- 37 dBA
- Sound Emission (Operating)
- 54 dBA
- 48.5 cm
- 52.1 cm
- 38.3 cm
- 28 kg
