The OKI MB770 mono MFP series combines high-quality output and four-in-one functionality with speed, reliability and ease of use - superior value from MFP that has a footprint small enough to fit easily into your environment. The MB770 has a robust super G3 fax with dual access, T.37 Internet faxing, a 3,000-entry address book, double-sided fax scanning, and the ability to let you send faxes directly from your PC. It can make your job easier - the MB770 MFP series is user friendly: network-ready right out of the box, with an intuitive operator panel that's simple to use: a 9" color touch-screen graphic display, an alphanumeric keypad and function buttons.
Enhance the productivity of your staff
The MB770's duplexing/reversing automatic document feeder (RADF) quickly scans both sides of a document. And, with its robust duty cycles, this durable device can be relied upon to handle large daily print and copy volumes. Scan at the machine or from your desk - turn hard-copy documents into electronic files with multiple options. Scan color or black and white documents in, and send them to your PC, a network folder, a USB stick, or to a list of e-mail addresses. -
The convenience of E-filing
Store your digital documents on or transfer them from "boxes" on the MFP's secure hard disk drive. Users have walk-up-and-print or pull-down (to their PCs) access to all documents in the public box, or access via password to documents in private boxes. Passwords can be assigned to specific users or shared within a department. -
Full-featured fax
The MB770 has a robust super G3 fax with dual access, T.37 Internet faxing, a 3,000-entry address book, double-sided fax scanning, and the ability to let you send faxes directly from your PC. It can make your job easier - the MB770 MFP series is user friendly: network-ready right out of the box, with an intuitive operator panel that's simple to use: a 9" color touch-screen graphic display, an alphanumeric keypad and function buttons. -
Improve your bottom line
The MB770 MFP series delivers cost-effective operation as well as an exceptional return on your investment. Its outstanding reliability and long-lasting consumables help you control operating costs and improve productivity.
- OKI MB770dnfax - multifunction printer - B/W
- Multifunction printer
- Fax Type
- Super G3 - plain paper
- Printing Technology
- LED (monochrome)
- Monthly Duty Cycle (max)
- 200000 pages
- Recommended Monthly Volume
- 30000 pages
- Max Copying Speed
- Up to 52 ppm
- Max Copying Resolution
- Up to 600 dpi
- Max Printing Speed
- Up to 52 ppm
- Max Printing Resolution
- Up to 1200 x 1200 dpi
- Max Fax Transmission Speed
- 33.6 Kbps
- Scanning
- 600 x 600 dpi
- Original Size
- A4 (210 x 297 mm) (max)
- Original Type
- Sheets
- Document Feeder Capacity
- 100 sheets
- Media Size
- 64 x 127 mm (min) - 216 x 1321 mm (max)
- Media Type
- Envelopes, plain paper, labels
- Standard Media Capacity
- 630 sheets
- Max Media Capacity
- 3160 sheets
- Bypass Feeder Capacity
- 100 sheets
- Output Trays Capacity
- 500 sheets
- Automatic Duplexing
- Yes (copying) Yes (printing) Yes (scanning)
- Connection Availability
- Interface
- USB 2.0, Gigabit LAN, USB host
- Office Machine Features
- Save to USB flash drive, scan to e-mail, scan to folder
- Power
- AC 230 V (50/60Hz)
- 52.2 cm x 56.4 cm x 67.5 cm
- 50 kg
- Environmental Standards
- ENERGY STAR Qualified
- 3-year warranty with product registration
- Fax Type
- Plain paper
- LED - monochrome
- 200000 pages
- 30000 pages
- Display Features
- Touch screen
- Interface
- Standard Memory
- 2 GB
- Hard Disk Drive
- 160 GB
Copying
- Max Copying Speed
- Up to 52 ppm
- Up to 600 dpi
- Max Document Enlargement
- 400%
- Max Document Reduction
- 25%
- Maximum Copies
- 999
- Copying Features
- ID Card Copy, Job Build
Printing
- Up to 52 ppm
- Printer Drivers / Emulations
- PCL 5e, PCL 6, PostScript 3, PCL 5c, PDF, XPS
- First Print Out Time B/W
- 5 sec
Scanning
- Optical Resolution
- 600 x 600 dpi
- Colour Depth
- 24-bit
Fax Machine
- Compatibility
- Super G3
- Max Transmission Speed
- 33.6 Kbps
Fax Machine Features
- Speed Dialing
- 3000 station(s)
- Broadcast Transmission
- 400 stations
Document & Media Handling
- Max Original Size
- A4 (210 x 297 mm)
- Original Type
- Sheets
- 100 sheets
- Min Media Size
- 64 x 127 mm
- Max Media Size
- A4
- Min Media Weight
- 64 g/m²
- Max Media Weight
- 250 g/m²
- Supported Media Type
- Supported Media Sizes
- A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), A6 (105 x 148 mm)
- Supported Envelope Sizes
- International DL (110 x 220 mm), Com-10 (105 x 241 mm), International C5 (162 x 229 mm), Com-9 (98 x 225 mm)
- 630 sheets
- 3160 sheets
- 100 sheets
- 500 sheets
- Bypass tray - 100 sheets size: 64 x 127 mm - 216 x 1321 mm weight: 64 g/m² - 250 g/m² , Input tray - 530 sheets - A4 (210 x 297 mm) weight: 64 g/m² - 220 g/m² , Output tray - 500 sheets , ADF - 100 sheets - A4 (210 x 297 mm) weight: 60 g/m² - 105 g/m²
- Speed Details
- Copying: up to 52 ppm - B/W , Printing: up to 52 ppm - B/W , Scanning: up to 40 ipm - colour , Scanning: up to 55 ipm - B/W
- 1 x USB 2.0 - 4 pin USB Type B , 1 x USB host - 4 pin USB Type A , 1 x LAN - RJ-45 , 2 x modem - RJ-11
- LDAP, Secure Print, SSL, TLS
- Operating System Support
- UNIX, Linux, MS Windows XP SP2 or later, Apple Mac OS X 10.4, Apple Mac OS X 10.5, MS Windows 7, MS Windows Vista SP1, MS Windows 7 64-bit Edition, MS Windows Vista SP2, Apple Mac OS X 10.6, Apple Mac OS X 10.7, MS Windows Vista SP2 64-bit Edition, MS Windows Server 2008 R2 x64 Edition, Apple Mac OS X 10.8, Windows 8, MS Windows Server 2008 SP1, MS Windows Server 2003 SP2, Windows 8 64-bit, MS Windows Server 2012 x64 Edition
- Voltage Required
- 870 Watt
- Power Consumption Sleep
- 2 Watt
- First Copy Out Time B/W
- 8 sec
- Consumables Included
- 1 x toner cartridge (black) - up to 10000 pages
- GS
- ENERGY STAR Certified
- Limited warranty - 3 years - on-site
- 52.2 cm
- 56.4 cm
- 67.5 cm
- 50 kg
- Sound Emission
- 30 dBA (idle) / 58 dBA (operating)
- 10 °C
- 32 °C
- 20 - 80%
OKI High Capacity Black Print Cartridge 36k Yield | In Stock | £297.54 |
OKI Standard Capacity Print Cartridge 18K | In Stock | £255.60 |
