IPS technology offers higher contrast, darker blacks and much better viewing angles than standard TN technology. The screen will look good no matter what angle you look at it.
This effect is much stronger with computer screens than with TV equipment. One of the factors responsible for this phenomenon is the blue light emitted by the screen. Therefore reducing the amount of blue light ultimately allows the eyes to feel less tired while working long hours with a computer screen.
IPS technology
IPS technology offers higher contrast, darker blacks and much better viewing angles than standard TN technology. The screen will look good no matter what angle you look at it. -
Blue light reducer
This effect is much stronger with computer screens than with TV equipment. One of the factors responsible for this phenomenon is the blue light emitted by the screen. Therefore reducing the amount of blue light ultimately allows the eyes to feel less tired while working long hours with a computer screen. -
Overdrive on/off
When very fast graphics are displayed your monitor can sometimes get blurry. Turning on the OverDrive feature will eliminate that.
- iiyama ProLite XUB2495WSU-B1 - LED monitor - 24"
- LED-backlit LCD monitor - 24"
- Energy Class
- Class A+
- USB 2.0 hub
- Panel Type
- IPS
- Aspect Ratio
- 16:10
- Native Resolution
- 1920 x 1200 at 60 Hz
- Pixel Pitch
- 0.27 mm
- Brightness
- 300 cd/m²
- Contrast Ratio
- 1000:1 / 5000000:1 (dynamic)
- Response Time
- 5 ms
- Colour Support
- 16.7 million colours
- Input Connectors
- HDMI, VGA, DisplayPort
- Height, pivot (rotation), swivel, tilt
- Screen Coating
- Matte
- Voltage
- AC 120/230 V (50/60 Hz)
- Black
- 53.2 cm x 23 cm x 39.7 cm
- 5.88 kg
- Environmental Standards
- TCO Certified Displays 9, ENERGY STAR Qualified
- DDC-2B, VESA DPMS, PSE Mark, TUV Bauart, VCCI Class B, CU
- 3-year warranty
- Display Type
- Energy Class
- Class A+
- Diagonal Size
- 24"
- Built-in Devices
- USB 2.0 hub
- Panel Type
- IPS
- Aspect Ratio
- 16:10
- Native Resolution
- Pixel Pitch
- 0.27 mm
- Brightness
- 300 cd/m²
- Contrast Ratio
- Colour Support
- Response Time
- 5 ms
- Vertical Refresh Rate
- 46 - 66 Hz
- Horizontal Refresh Rate
- 24 - 82 kHz
- Horizontal Viewing Angle
- +89 / -89
- Vertical Viewing Angle
- +89 / -89
- Screen Coating
- Matte
- Backlight Technology
- LED backlight
- OSD Languages
- Czech, English, German, French, Italian, Polish, Russian, Spanish, Japanese
- HDCP, Eco-Mode, Overdrive technology, Advanced Contrast Ratio (ACR), Flicker Free technology, i-Style Color, Blue Light Filter technology
- Black
- 5.88 kg
Audio
- Speakers - stereo
- Output Power / Channel
- 2 Watt
- HDMI , VGA , DisplayPort , USB 2.0 upstream , 4 x USB 2.0 downstream , Headphones
Mechanical
- Tilt Angle
- -5/+22
- Swivel Angle
- 320
- Rotation Angle
- 90
- Height Adjustment
- 130 mm
- VESA Mounting Interface
- 100 x 100 mm
- Cables Included
- 1 x DisplayPort cable , 1 x USB cable
- Security Slot Type
- Kensington security slot
- Input Voltage
- Power Consumption (Typical)
- 23 Watt
Sustainability Information
- TCO Certified
- ENERGY STAR Certified
- Limited warranty - 3 years
