iiyama XB2472HSUC-B1 23.6" 1920x1080 8ms VGA DVI DP Monitor
Quicklinx: CW1RWS00 Mfr#: XB2472HSUC-B1
The XB2472HSUC-B1 is an advanced desktop monitor for demanding users looking for a high-quality. The VA matrix offers wide viewing angles and sharp contrast. The blue light reducer function with flicker-free LCD technology reduces eye strain and offers a more comfortable viewing experience.
iiyama ProLite XB2472HSUC-B1 - LED monitor - Full HD (1080p) - 23.6"
LED-backlit LCD monitor - 23.6"
Microphone, 2.0 megapixel camera, USB 2.0 hub
Panel Type
VA
Aspect Ratio
16:9
Native Resolution
Full HD (1080p) 1920 x 1080
Pixel Pitch
0.2715 mm
Brightness
250 cd/m²
Contrast Ratio
3000:1 / 12000000:1 (dynamic)
Response Time
8 ms
Colour Support
16.7 million colours
Input Connectors
DVI, VGA, DisplayPort
Display Position Adjustments
Voltage
AC 120/230 V (50 - 60 Hz)
55.7 cm x 23 cm x 40.65 cm
5.8 kg
Environmental Standards
ENERGY STAR Qualified
DDC-2B, VESA DPMS, TUV Bauart, CU
Display Type
Diagonal Size
23.6"
Built-in Devices
Panel Type
VA
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.2715 mm
Brightness
250 cd/m²
Contrast Ratio
Colour Support
Response Time
8 ms
Vertical Refresh Rate
50 - 75 Hz
Horizontal Refresh Rate
30 - 94 kHz
Horizontal Viewing Angle
+89 / -89
Vertical Viewing Angle
+89 / -89
Backlight Technology
LED backlight
OSD Languages
Czech, English, German, French, Italian, Polish, Russian, Spanish, Dutch
Eco-Mode, matte, X-Res Technology, Flicker Free technology, i-Style Color, Blue Light Filter technology
5.8 kg
Audio
Speakers - stereo
Output Power / Channel
2 Watt
VGA , DVI (HDCP) , HDMI (HDCP) , Audio line-out , USB 2.0 upstream , 2 x USB 2.0 downstream
Mechanical
Tilt Angle
-5/+22
Swivel Angle
90
Rotation Angle
90
Height Adjustment
130 mm
VESA Mounting Interface
100 x 100 mm
1 x DisplayPort cable , 1 x USB cable
Input Voltage
Power Consumption (Typical)
21.5 Watt
Sustainability Information
ENERGY STAR Certified
