Stylish ultra-flat front design makes the ProLite XUB2792QSU perfect for multi-monitor set-ups. The IPS panel technology offers accurate and consistent color reproduction with wide viewing angles and the WQHD resolution means the XUB2792QSU can accommodate more information on the screen than a Full HD display. High contrast and brightness values guarantee the monitor will provide excellent performance for photographic and web design, and the height adjustable stand ensures you can easily adjust the screen position to your preferences. It is a great choice for both multi-monitor digital signage and office applications.
- iiyama ProLite XUB2792QSU-W1 - LED monitor - 27"
- LED-backlit LCD monitor - 27"
- Energy Label QR Code URL
- Https://eprel.ec.europa.eu/qr/360740
- Energy Class
- Class G
- Energy Consumption per Year
- 50 kWh
- Power Consumption (On mode)
- 29.7 W
- Adaptive-Sync Technology
- AMD FreeSync
- USB 3.0 hub
- Panel Type
- IPS
- Aspect Ratio
- 16:9
- Native Resolution
- 2560 x 1440 at 70 Hz
- Pixel Pitch
- 0.233 mm
- Brightness
- 350 cd/m²
- Contrast Ratio
- 1000:1 / 5000000:1 (dynamic)
- Response Time
- 5 ms
- Colour Support
- 1.07 billion colours
- Input Connectors
- HDMI, DVI, DisplayPort
- Height, pivot (rotation), swivel, tilt
- Screen Coating
- Matte
- Voltage
- AC 120/230 V (50/60 Hz)
- White
- 61.1 cm x 23 cm x 39.7 cm
- 6.1 kg
- Environmental Standards
- TCO Certified Displays 9, ENERGY STAR Qualified
- TUV GS, DDC-2B, VESA DPMS, CU
- 3-year warranty
- Display Type
- Energy Class
- Class G
- 50 kWh
- Diagonal Size
- 27"
- AMD FreeSync
- Built-in Devices
- USB 3.0 hub
- Panel Type
- IPS
- Aspect Ratio
- 16:9
- Native Resolution
- Pixel Pitch
- 0.233 mm
- Brightness
- 350 cd/m²
- Contrast Ratio
- Colour Support
- Response Time
- 5 ms
- Vertical Refresh Rate
- 55 - 75 Hz
- Horizontal Refresh Rate
- 30 - 89 kHz
- Horizontal Viewing Angle
- +89 / -89
- Vertical Viewing Angle
- +89 / -89
- Screen Coating
- Matte
- Backlight Technology
- LED backlight
- OSD Languages
- Czech, English, German, French, Italian, Polish, Russian, Spanish, Dutch, Japanese, Chinese
- Advanced Contrast Ratio (ACR), Flicker Free technology, blue light reduction, i-Style Color
- White
- 6.1 kg
Audio
- Speakers - stereo
- Output Power / Channel
- 2 Watt
- DVI , HDMI , DisplayPort , USB 3.0 upstream , 2 x USB 3.0 downstream , Audio line-out (mini-jack)
Mechanical
- Tilt Angle
- -5/22
- Swivel Angle
- 90
- Rotation Angle
- 90
- Height Adjustment
- 130 mm
- VESA Mounting Interface
- 100 x 100 mm
- Cables Included
- 1 x HDMI cable , 1 x DisplayPort cable , 1 x USB cable
- Input Voltage
- 29.7 W
- Power Consumption SDR (On mode)
- 29.7 kWh/1000h
- Power Consumption (Typical)
- 33 Watt
Sustainability Information
- TCO Certified
- ENERGY STAR Certified
- Limited warranty - 3 years
