iiyama ProLite XUB2294HSU-B1 22" 1920x1080 4ms VGA HDMI DisplayPort LED Monitor
Quicklinx: FJ0LWS00 Mfr#: XUB2294HSU-B1
The ProLite XUB2294HSU featuring VA panel technology guarantees accurate and consistent color reproduction with wide viewing angles. Triple input configuration (VGA, HDMI, DisplayPort) and a USB hub assure compatibility with many platforms.
  • VA matrix
    VA panel technology offers higher contrast, darker blacks and much better viewing angles than standard TN technology. The screen will look good no matter what angle you look at it.
  • Height-adjustable stand
    With a height-adjustable stand you will create an ergonomic work posture and position that meets all health and safety requirements.
iiyama ProLite XUB2294HSU-B1 - LED monitor - Full HD (1080p) - 22"
LED-backlit LCD monitor - 22"
Energy Label QR Code URL
Https://eprel.ec.europa.eu/qr/366778
Energy Class
Class E
Energy Consumption per Year
23 kWh
Power Consumption (On mode)
16.5 W
USB 2.0 hub
Panel Type
VA
Aspect Ratio
16:9
Native Resolution
Full HD (1080p) 1920 x 1080 at 75 Hz
Pixel Pitch
0.248 mm
Brightness
250 cd/m²
Contrast Ratio
3000:1 / 80000000:1 (dynamic)
Response Time
4 ms
Colour Support
16.7 million colours
Colour Gamut
72% NTSC, 99% sRGB
Input Connectors
HDMI, VGA, DisplayPort
Display Position Adjustments
Screen Coating
Matte
Voltage
Matte black
48.85 cm x 21 cm x 35.2 cm
4.7 kg
Environmental Standards
TCO Certified Displays 9, ENERGY STAR Qualified
TUV GS, DDC-2B, PSE Mark, REACH, VCCI Class B, CU, REACH SvHC
3-year warranty
Display Type
Energy Class
Class E
23 kWh
Diagonal Size
22"
Viewable Size
21.5"
Built-in Devices
USB 2.0 hub
Panel Type
VA
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.248 mm
Brightness
250 cd/m²
Contrast Ratio
Colour Support
Colour Gamut
72% NTSC, 99% sRGB
Response Time
4 ms
Vertical Refresh Rate
55 - 75 Hz
Horizontal Refresh Rate
30 - 83 kHz
Horizontal Viewing Angle
+89 / -89
Vertical Viewing Angle
+89 / -89
Screen Coating
Matte
Backlight Technology
LED backlight
OSD Languages
Czech, English, German, French, Italian, Polish, Russian, Spanish, Dutch, Japanese
Ultra Slim Design, HDCP, Eco-Mode, High Frame Rate Control (Hi-FRC), Advanced Contrast Ratio (ACR), Flicker Free technology, blue light reduction, i-Style Color, 8-bit gamma, 72% NTSC colour gamut, 99% sRGB colour gamut
Matte black
4.7 kg
Audio
Speakers - stereo
Output Power / Channel
1 Watt
VGA , HDMI (HDCP) , DisplayPort , USB 2.0 upstream (Type B) , 2 x USB 2.0 downstream (Type A) , Headphones (mini-jack)
Mechanical
Tilt Angle
-5/+22
Swivel Angle
90
Rotation Angle
90
Height Adjustment
130 mm
VESA Mounting Interface
100 x 100 mm
1 x HDMI cable
Security Slot Type
Kensington security slot
Input Voltage
16.5 W
16.5 kWh/1000h
Power Consumption (Typical)
19 Watt
Power Consumption Stand by
0.5 Watt
Power Consumption (Off Mode)
0.26 Watt
Sustainability Information
TCO Certified
ENERGY STAR Certified
Limited warranty - 3 years - on-site
5 °C
35 °C
10 - 80% (non-condensing)
