LED backlit LCD screen featuring VA panel technology, guarantees accurate and consistent color reproduction with wide viewing angles. Triple input configuration assures compatibility with many platforms.
VA Matrix
VA panel technology offers higher contrast, darker blacks and much better viewing angles than standard TN technology. The screen will look good no matter what angle you look at it. -
HAS + Pivot
With a height adjustable stand you will create an ergonomic work posture and position that meets all health and safety requirements. This will not only prevent any health issues but will also increase your productivity. The pivot function allows the screen to rotate from landscape to portrait orientation. This functionality can be useful if the application requires more height than width. -
Flicker-free + Blue Light
The ultimate solution for the comfort and health of your eyes. Flicker-free monitors with the blue light reducer function substantially reduce the strain and fatigue caused by flickering and blue light emittance of regular monitors. -
Integrated speakers
Playing with friends? Use the integrated high-quality speakers. Don't want to disturb anybody? Plug your headset into the headphone socket and turn the volume up. -
Advanced Contrast Ratio
Contrast Ratio is a measurement of the difference between the darkest black and the brightest white your monitor can display. Advanced Contrast Ratio is a feature that automatically adjusts contrast and brightness of the screen to assure perfect picture quality while watching films and playing games.
- iiyama ProLite XB2474HS-B2 - LED monitor - Full HD (1080p) - 24"
- LED-backlit LCD monitor - 24"
- Energy Class
- Class F
- Power Consumption (On mode)
- 20.6 W
- Panel Type
- VA
- Aspect Ratio
- 16:9
- Native Resolution
- Full HD (1080p) 1920 x 1080
- Pixel Pitch
- 0.272 mm
- Brightness
- 250 cd/m²
- Contrast Ratio
- 3000:1 / 12000000:1 (dynamic)
- Response Time
- 4 ms
- Colour Support
- 16.7 million colours (8-bit)
- Input Connectors
- HDMI, VGA, DisplayPort
- Height, pivot (rotation), swivel, tilt
- Voltage
- AC 100/240 V (50/60 Hz)
- Black
- 54.6 cm x 21 cm x 50.3 cm
- 5.3 kg
- Environmental Standards
- ENERGY STAR Qualified
- TUV Bauart, CU, REACH SvHC
- 3-year warranty
- Display Type
- Energy Class
- Class F
- Diagonal Size
- 24"
- Viewable Size
- 23.6"
- Panel Type
- VA
- Aspect Ratio
- 16:9
- Native Resolution
- Pixel Pitch
- 0.272 mm
- Brightness
- 250 cd/m²
- Contrast Ratio
- Colour Support
- Response Time
- 4 ms
- Vertical Refresh Rate
- 55 - 75 Hz
- Horizontal Refresh Rate
- 24 - 80 kHz
- Horizontal Viewing Angle
- +89 / -89
- Vertical Viewing Angle
- +89 / -89
- Backlight Technology
- LED backlight
- OSD Languages
- English, German, French, Italian, Portuguese, Polish, Russian, Dutch, Estonian, Japanese
- HDCP, Eco-Mode, Advanced Contrast Ratio (ACR), Flicker Free technology, blue light reduction, i-Style Color, a-Si technology
- Black
- 54.6 cm x 21 cm x 50.3 cm - with stand
- 5.3 kg
Audio
- Speakers - stereo
- Output Power / Channel
- 2 Watt
- VGA , DisplayPort , HDMI , Headphones
Mechanical
- Tilt Angle
- -3/+22
- Swivel Angle
- 90
- Rotation Angle
- 90
- Height Adjustment
- 130 mm
- VESA Mounting Interface
- 100 x 100 mm
- Cables Included
- HDMI cable
- Security Slot Type
- Kensington security slot
- Input Voltage
- 20.6 W
- Power Consumption SDR (On mode)
- 20.6 kWh/1000h
- Power Consumption (Typical)
- 19 Watt
- Power Consumption Stand by
- 0.5 Watt
- 0.5 Watt
- Dimensions & Weight Details
- Without stand - width: 54.6 cm - depth: 21 cm - height: 37.3 cm , With stand - width: 54.6 cm - depth: 21 cm - height: 50.3 cm - weight: 5.3 kg
- ENERGY STAR Certified
- 3-year warranty
